Finally pulled the trigger on a 113" Ultima
Old Apr 10, 2009 | 02:19 AM
  #31
pistole's Avatar
pistole
- congrats on your new engine.
- how's she treating you ?
Old Apr 10, 2009 | 04:51 AM
  #32
pajoe's Avatar
pajoe
Originally Posted by IronButt62
20 mile break in run with NO PROBLEMS!
That sucker is smooth and seems to have a lot of power. No suprise there. Still no leaks or weird engine noises so life is good.
Still had some popping through the carb, but the idle was up real high when was it was finally warmed up. I adjusted it again and it seems better.
Going to let it cool all day and put the rest of the first 100 on this evening. Change the oil tonite and try to get a couple of hundred tomorrow. It's supposed to be sunny and 60. <G>
Need to adjust new exhaust though. Not enough clearance when leaning right.
Here is the bike reassembled. Still need a heat shield and some bleche white for the tires, but that's my baby.
Deet
I always liked the older red and white Harleys, yours looks really good. The top end on our Ultima 113 was quieter than my 80" but did get much louder when I switched to full synthetic oil, I am still not sure if I will stay with synthetic.
You may want to take a look at the setting for the accelerator adjustment, I know Mikuni says set it at 2 mm but on mine it seemed to work better adjusted a little closer, to where the lever almost touched causing the extra fuel to be sent to the carb sooner, which helps eliminate any temporary lean condition when you first hit the throttle.
steffridesabuell
EVO
Sep 27, 2023 08:28 AM
Fatboy931
EVO
72
Jul 29, 2010 11:44 AM
johntheone
Apr 4, 2008 12:21 PM
lionsm13
Jan 2, 2008 10:46 PM
AK97fxdwg
May 4, 2007 02:36 PM
