Upper Brake Line Replacement Question
Old Aug 11, 2011 | 11:31 AM
Plow64's Avatar
Plow64
Question Upper Brake Line Replacement Question
I'm in the middle of installing a set of Wild One 518's on my RK. (Still waiting on the cables +4, grips and wire extension kit to arrive in the mail.) I'm not sure if I'll be able to re-use the stock upper brake line or if I'll have to replace it with one a few inches longer until I actually mount the handlebars and see if the OEM ones are too short.
If I do need a longer brake line, can the OEM rubber hose be disconnected from the steel tubing and replaced with a longer rubber hose or do I have to buy the entire steel brake tubing & hose together as one unit? I'd rather just replace the hose, if that's possible, and keep it simple.
The attached picture shows the rubber hose with the steel tubing attached on each end.
Thanks! Plow
Old Aug 11, 2011 | 01:51 PM
miacycles's Avatar
miacycles
You cannot remove the stock brake line in pieces, you will have to replace it with an aftermarket line. Be sure to get a teflon lined hose as they work much better. Hope this helps.,
Old Aug 11, 2011 | 01:56 PM
Plow64's Avatar
Plow64
It does help, thanks miacycles.
Old Aug 12, 2011 | 09:58 AM
grbrown's Avatar
grbrown
For reasons that are difficult to understand Harley make their brake pipes very complicated, with bits of rubber hose bonded with bits of metal piping. After-market hoses are supremely simple, being just a piece of flexible hose with a fitting at each end. I have stainless braided lines on all my Evo's brakes. You can buy them as ready-made kits for your bike, including all the hardware you need, which if you have stock bars is very easy!
Old Aug 12, 2011 | 11:31 AM
Plow64's Avatar
Plow64
Thanks grbrown. I'm still holding out hope that the stock lines will work, but won't know for sure until I get everything bolted together. Still waiting on parts to arrive in the mail.
Old Aug 13, 2011 | 04:09 AM
Spanners39's Avatar
Spanners39
There isn't a lot of spare length in the stock hose and its not the best hose you can use anyway so just go for the braided one.
Old Aug 13, 2011 | 05:24 AM
moose thecat's Avatar
moose thecat
From: west central michigan 2 miles from the big pond
I used the stock lower line on my 98 ultra.I cut the upper metal line with a tubeing cutter and flared it with a flaring tool and got a an to flar adaptor from a autosupply store then went to braded line.It saved me a fue bucks.About $35.00 to lengthen the lines.
Old Aug 13, 2011 | 05:41 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Don't Mickey Moose it. They're your brakes. Replace the whole setup.
Old Aug 13, 2011 | 10:24 AM
Plow64's Avatar
Plow64
Good points. The lines are 16 years old. I'll replace the whole assembly.
LN2_Casey
Harley-Davidson Street
May 18, 2018 01:08 PM
jtayers
Jul 9, 2015 07:08 PM
InsomniaInc
Jan 4, 2013 03:57 PM
ejohnson1
Mar 27, 2010 03:00 PM
HarleyArcher
Feb 20, 2008 07:16 AM
