which brand lifters you run?
Old Nov 18, 2011 | 09:45 PM
langwilliams's Avatar
langwilliams
Default which brand lifters you run?
I picked up a 94 st an it runs great an is a sweet ride. It has around 55K on the clock. An indy told me to consider replacing the roller lifters for piece of mind so one doesn't come apart an ruin my motor. Any thoughts on this an what brand do you run. It sounds like it has an after market cam in it too. He also recomends having the cam bearing inspected when replacing the lifters. Any info appreciated.
Old Nov 18, 2011 | 10:47 PM
Spanners39's Avatar
Spanners39
I use genuine H-D ones.
Old Nov 19, 2011 | 07:36 AM
Dr.Hess's Avatar
Dr.Hess
H-D (oem).
Old Nov 19, 2011 | 12:40 PM
FXD_One's Avatar
FXD_One
Harley Davidson ( Oem ) No noise even with an upgraded cam.
Old Nov 20, 2011 | 07:53 AM
1997bagger's Avatar
1997bagger
HD "B's"lifters are hard to beat in stock and mild camshaft engines but collasped (stayed collasped) a couple "B" lifters with a high rpm romps with a Woods cam, currently running the Ultima (Johnsons) and has been ok with the same riding style. Really struggle with the price of S&S, Jim's for 4 lifters and the Johnsons have been holding up in the 600 plus lift Ultima engines after they went to the Johnsons.
Old Nov 21, 2011 | 10:08 AM
rivercityslim's Avatar
rivercityslim
Hd 'b'.
Old Nov 21, 2011 | 10:52 AM
RidemyEVO's Avatar
RidemyEVO
HD OEM, atf in the primary , belray in gearbox , castrol in engine and highest octane gas I can get.
Old Nov 23, 2011 | 01:38 PM
Uncle G.'s Avatar
Uncle G.
I had the rollers in a OEM lifter go bad on me at 49,000 miles. This was before the "B" revision, which eliminated the separate inner race and enlarged the roller axle. That ended up costing me a motor.
I run the improved lifters since then, but I DO change them every 40,000 miles for peace of mind. No problems with the "B" revison lifters so far.
Changing lifters is easy enough that I can do it myself in a couple of hours (once I installed quick install pushrods).
Old Nov 23, 2011 | 01:41 PM
Uncle G.'s Avatar
Uncle G.
I'd also make sure the cam bearing is a Torrington B-138 (the good one). It SHOULD have been changed when the cam was changed, but you won't know if you don't check.
cdestuck
Jul 27, 2019 07:46 PM
1/2crazedbikr
EVO
13
Mar 2, 2014 11:13 AM
Notgrownup
Exhaust System Topics
16
Sep 7, 2012 06:34 AM
Cohiba_Joe
Apr 26, 2010 11:08 PM
jpooch00
EVO
Dec 7, 2008 04:40 AM
