You should be over 100 on compression,
Instead of holding valves open, you might not be opening them enough.
Looking at the Velva touch web site, I see they say 1.5 turns on the pushrod adjustment,
it depends on the TPI as to how many turns after zero lash,
most pushrods are adjusted 2.5 to 3.5 turns, more like 18 flats for 32tpi.
See what pushrods you have, or measure the pitch with a thread gauge.
Some pushrod sets have two longs and two shorts also.
I have about the same compression. I had 90 psi, then I had the cylinders honed and put in new rings, now I get about 80. She's a dog, but she goes. BTW Traildog, you had the cylinders honed I think, right? Did you install new rings to go along with the larger bore?
They are Velva Touch Pushrods. 1 long and 3 same length.
They saying 1.5 turns for the front cyl pushrods, and 1 turn for the rears.
The lifters must have some type of limiters in them, sounds like it would be easy to go too tight on them.
10. CAUTION !! Before rotating the engine to install the rear cylinder pushrods allow the lifters to bleed down, (The pushrods will turn by hand when ready) failure to this could bend a valve. 11. Position the rear cylinder lifter block tappets on the heel of the cam using the method in step 8, then adjust the pushrods as described in step 9, EXCEPT, turn the adjusters out one (1) full turn, or six (6) wrench flats! Expand the sleeves and install retainers.
