getting ready to "push the button"
Old Jan 20, 2013 | 03:59 PM
  #201
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by traildog
Last time I did THAT, I was tasting fuel for a week......I'll ask my son to do it.......
Or you could change your petcock and never have this problem again.
Old Jan 20, 2013 | 04:03 PM
  #202
Doug S's Avatar
Doug S
TD,
Use clear hose, you can see the fuel comming befor you have to taste it.
Ds
Old Jan 20, 2013 | 04:04 PM
  #203
texashillcountry
Dirt don't hurt
Try the either. I've never had any problems using carb cleaner but what the hell it might work better.
When you installed your pistons how much did you stagger the gaps in your rings?
Lean means not enough fuel.
Get a multi-meter and check out your coil.
If none of the above works get a Diet Dew and piece of cake and relax for a while.
Old Jan 20, 2013 | 04:31 PM
  #204
traildog's Avatar
traildog
Just got back with it.Battery needs a bit of charging.
Guy who honed it set the stagger then put little dots on the piston to make sure they didn't move.
Got one but I couldn't find instructions for a single fire coil
Already jacked up on dew.........
Old Jan 20, 2013 | 04:43 PM
  #205
Jim Kraft's Avatar
Jim Kraft
I have drained my tank by putting a hose on the vacuum nipple on the back side of the pet ****, and just suck on it enough to get gas to flow. It does not take much, and you don't get gas in your mouth that way. I have drained three gallons that way. I do put a fuel line on the pet **** to drain the gas into a can. Be sure and have it in reserve to get it all out. If it does not drain when you suck on the vacuum nipple, that is your problem. They do go bad if the vacuum diaphram gets a hole in it. I took mine apart and put the spring on the other side of the diaphram so that it works like a normal pet ****. The other thing that can happen is that the vacuum line is leaking and not sucking on the diaphram.
Old Jan 20, 2013 | 04:46 PM
  #206
Doug S's Avatar
Doug S
Needless to say, that stuff is really flamable, a spark from a battery charger clamp could set it off. Disconnect the charger befor cranking. Just saying since your luck with this project has not been great...
Ds
Old Jan 20, 2013 | 04:47 PM
  #207
traildog's Avatar
traildog
OK, ether dam near got her started. I am checking the petcock with my vaccum pump.
Old Jan 20, 2013 | 04:58 PM
  #208
traildog's Avatar
traildog
put some vaccum on the petcock and fuel started to flow.
Old Jan 20, 2013 | 05:02 PM
  #209
traildog's Avatar
traildog
Ds
Hey, I haven't blown anything up................................................ .yet.
Old Jan 20, 2013 | 05:27 PM
  #210
traildog's Avatar
traildog
oh boy.......she's gonna go........i can feel it...........
