Oil question
Old Jun 9, 2013 | 02:54 PM
HD4EVR's Avatar
HD4EVR
Default Oil question
While my girlfriend and I are cruising down the freeway, a drop of oil will land on her right shin every 10 minutes or so. Is this normal?
Old Jun 9, 2013 | 02:56 PM
Spanners39's Avatar
Spanners39
Probably due to reversion and the oil is coming from her aircleaner. If you can't find a leak on the motor then pull the aircleaner cover and have a look to see if there is oil in there....or stop riding behind old British bikes ;-)
Old Jun 10, 2013 | 01:42 PM
grbrown's Avatar
grbrown
No it isn't normal! As Spanners suggests (being British I'll ignore his comment about British bikes!) take a look at the air cleaner. When new your bike had a breather pipe that went into the airbox, to consume any oil fumes. If the airbox has been replaced with an aftermarket air filter there is no knowing what has been done to the breather. Your bike is a 'head breather', meaning there are breather ports in both heads, either side of the carb.
Added later! No its not! It's a bottom breather, but the breather still went into the stock airbox.
Old Jun 10, 2013 | 05:02 PM
Spanners39's Avatar
Spanners39
You could just wrap her right shin in Saran Wrap......
Old Jun 10, 2013 | 05:12 PM
Uncle G.'s Avatar
Uncle G.
My "head breather" has always misted some oil vapor from the breather ports which vent into the air cleaner. The oil mist will eventually saturate the air cleaner and drip off the bottom. Yes, I've tried running the oil level low, but all it does is make the motor run hot. I just fold up a paper towel and wedge it between the bottom of the filter and the cover and change it every few hundred miles.
Old Jun 10, 2013 | 05:20 PM
bluharley's Avatar
bluharley
Not that this ie your problem, but my air filter is soaked in oil. I did it quite some time ago, and it's still dripping all over the place. Guess I used too much oil!
Old Jun 10, 2013 | 07:15 PM
ironoxide's Avatar
ironoxide
Default rocker box cover
I had a leaking rocker box cover that exhibited the same symptoms.
Old Jun 10, 2013 | 08:18 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If you have a K/N air cleaner you can simply wash your air cleaner every time you change the oil.
Then put it back in dry.
The oil from the breather will soak into the air filter so there is no need to re-oil the filter.
Doing this stopped mine from dripping on me.
sctrcks17
Milwaukee Eight (M8)
Jun 14, 2018 12:14 PM
Twisted Cherry RGU
Apr 9, 2017 10:03 AM
riley drake
Nov 12, 2011 06:00 PM
safetydave7777
Aug 3, 2011 08:17 PM
Anthonyamastr52
EVO
Apr 1, 2009 01:02 PM
