mismatched rockerarms ?
Old Jan 6, 2014 | 02:34 PM
machinehed's Avatar
machinehed
Unhappy mismatched rockerarms ?
Rebuilding a 1990 Evo. and i think i might have mistakenly switched the exhaust and intake rockers for the front cylinder ?
I am certain about the rocker locations for the rear cylinder and labeled them correctly etc. Im not sure about the fronts for two reasons...
1) it is possible i mismatched the labeling of the front rockers during dissasembly.
2) the stamped #s on all four rockers indicate that i actually did mismatch the two rockers for the front cylinder .
The stampings on the rear cyl. exhaust rocker are A15 38. Intake is stamped 36. (I am sure about these).
The stampings on the front cyl. exhaust are 38 and the intake is A15 38. (i am not sure about these).
Did i screw up here ?
Old Jan 6, 2014 | 03:22 PM
grbrown's Avatar
grbrown
IIRC the two rocker assemblies are identical. In any event one end of each rocker contacts the valve, the other the pushrod, Even if they are the wrong way around, it should be obvious, by comparing the two sets. It's a while since I last had mine apart, but I can't think how you can screw up!
Old Jan 6, 2014 | 05:33 PM
Tom84FXST's Avatar
Tom84FXST
The front exhaust is the same as the rear intake and vice-versa ...you could not reverse them on one head and get it together
Old Jan 6, 2014 | 05:36 PM
machinehed's Avatar
machinehed
Default mismatched rockers
Thanks for the reply grbrown ., i am aware that it is a very good practise to replace all parts back into there original home .
The rockers are worn to there original valve and pushrod contact points and i was consirned that by inadvertantly switching the rocker arms for one cyl. only from exhaust to intake or visa vera ., it would not be proper and as this is my first Harley rebuild i want to be correct etc. I personaly dont think its a big deal but the manuals and common sense dictate that this is best etc.
Regarding the 1990 Evo... have you had any issues with swapping cams .?
I purchased a Andrews EV 27 and now learn that the cam gear must be swapped to the old gear etc.???
Old Jan 6, 2014 | 05:50 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Must be?? NO
Should be ?? YES
I swapped mine before I found this forum and I just pulled the old one and slid in the new one (I also replace the cam bearing while I was there).
It made a hell of a whine but I was told it was no big deal and that it would go away in about 5k miles. It did.
I now have about 35k on the bike since I did the swap.
Still going strong.
Old Jan 6, 2014 | 06:46 PM
machinehed's Avatar
machinehed
Default Andrews cam gear.
Originally Posted by texashillcountry
Must be?? NO
Should be ?? YES
Still going strong.
Thanks Tex. , did you notice anything nasty in the next oil change or was everyrthing ok.?
From what i understand there is a big deal between the ones who change over the gear and the ones who dont and let it ride .?
A heavy gear whine seems to me to be metal loosing metal as it meshes .???
If the cam gear oil goes straight to the oil filter and is caught there , i would say ok.? But Damned ???
Old Jan 6, 2014 | 06:53 PM
texashillcountry
Dirt don't hurt
Sorry man I don't remember.
Old Jan 6, 2014 | 08:19 PM
GraemeR's Avatar
GraemeR
I always swap the gear on the cam body....I do not have a press but the local dealer does the job for me if I take all the parts into him.
Way less stressful and cheaper than trying to measure what gear size you need etc.
CookUltraClassic
May 10, 2019 09:17 PM
98hotrodfatboy
EVO
156
Mar 6, 2019 11:43 AM
EX300
Nov 4, 2012 09:52 AM
mk2007
Ironhead
May 24, 2008 06:00 AM
ride2tires
Exhaust System Topics
Oct 2, 2007 07:48 AM
