break in
antique bikes that shair oil and gas in the same tank with different compartments - when the motor is new will boil the gas in the shaired tank from the hot oil, i have seen the paint peel on some -
evos dont have that added little drama knowing the fuel tank is 60 plus years old and soldered together not welded
One of the most noteworthy improvements in recent engine design is the reduction of 'parasitic losses'. By using superior materials the reciprocating parts can be reduced in weight, friction losses can be reduced, also inertia losses. A simple example is the 'beehive' valve spring, which use a smaller diameter spring keeper, also light spring (because of the reducing diameter coils), but these are possible due to lighter weight valves. So the power from the crankshaft, required to open each valve, is lower. This approach continues throughout even our latest Harley engines (and my S&S Evo!).
One of the reasons synthetic oils are suitable, despite being thinner than p1ss, is that running clearances between mating moving parts are also less. I could go on! Such things do offer the prospect of shorter running in times.
lunched both motors
I'd switch to an Andrews cam as their quality and longevity is from my experience far better than crane.
that apart running in, give it a few short hard full throttle blasts to force the rings hard out against the bores and bed them in
change oil after 50 miles to get rid of any crap that has got into motor
babying motors and running them in slowly usually glazes the bores and from my experience you end up with a smoking slow motor with lots of blowby and poor performance
