Starter not engaging.......?
Old May 14, 2014 | 05:30 AM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by Spanners39
Fixed with new parts...its what I do... The starter clutch is the same as some Toyota starters but not sure its any cheaper that way,
Really? Got a picture of that one?
Old May 14, 2014 | 03:53 PM
Spanners39's Avatar
Spanners39
Originally Posted by Turret_plug
It was the jackshaft screw....... There's a flat washer with a tab (lock washer) that broke off........ So, I ordered a "spyke" jackshaft kit and a new gasket....... All should be good.
All good then
Old May 28, 2014 | 07:42 PM
Turret_plug's Avatar
Turret_plug
Grrrrr...... Not the jackshaft screw and lock washer at all! It's the damn starter clutch....!
First off, that starter is a real B to get out of evo bikes, and an even bigger pain to crack open. Starter shaft spun freely in both directions (bad starter clutch) I'm on the fence now...... Just buy a new starter, or the clutch and use the spyke kit I have to essentially rebuild my starter?
Any opinions? There's a gazillion starters on fleabay, who's a good vendor/brand?
Old May 28, 2014 | 07:46 PM
Beemervet's Avatar
Beemervet
The usual suspect..........
Old May 28, 2014 | 07:51 PM
Turret_plug
Lol..... Explain? Is this normally problematic? I've had only 2 other EVO bikes, and they were both kick start bikes. I've had a number of TC bikes, and NEVER had a starter go out
Old May 28, 2014 | 09:09 PM
traildog's Avatar
traildog
I had an aftermarket starter on my FLHTP and I still replaced 2 clutches. I'd replace the clutch. But that's just me...... and I like wrenching........
Old May 28, 2014 | 10:13 PM
Turret_plug
I like wrenching too...... But not paying to replace faulty parts all the time
Old May 28, 2014 | 10:49 PM
Spanners39's Avatar
Spanners39
Evo Dyna starters are easy as to extract and no biggie to fix the starter clutch....you could save yerself a ton of cash!
Old May 29, 2014 | 05:28 AM
Turret_plug
If only I had a Dyna.......! That oil tank doesn't leave much clearance. Finally got the starter cracked open, took an impact driver to get those screws out...... Pretty good design, at least I know it won't rattle apart
Hoosier bird
11
Feb 22, 2014 12:33 PM
mostSilly
EVO
11
Aug 1, 2010 12:46 AM
hoodlum
May 21, 2008 03:15 PM
02glide
Nov 18, 2006 06:05 PM
Joker441
Shovelhead
Feb 8, 2006 04:56 AM
