Evo shake
Old Jun 18, 2014 | 08:45 PM
  #141
Spanners39's Avatar
Spanners39
Originally Posted by kp877
I can't win. If you tell you now I get blasted and told I'm wrong. If I wait and I'm wrong you guys tell me I wasted my time. But, if it works and I wait I'm happy. If I tell you now, by the time I'm ready to test it I'll feel defeated already.
Only ********* will do that, the cool kids will watch and learn from what you do...
Old Jun 18, 2014 | 09:04 PM
  #142
tmanbuckhunter's Avatar
tmanbuckhunter
What about trannys?
Old Jun 18, 2014 | 09:40 PM
  #143
apples402's Avatar
apples402
i for one am interested in the outcome of this, i wish along the way i would have been of some help, there are members way more qualified and knowledgeable than me. however i am curious and have been following your thread because i have a small vibration at the same range (very minor compared to yours) but your fix may help me and lots of dyna owners in the future
Old Jun 18, 2014 | 09:45 PM
  #144
92Fatty's Avatar
92Fatty
Just throw a set of Heritage bars on it. Everyone says they a so comfortable.
Old Jun 18, 2014 | 09:49 PM
  #145
HarDlife's Avatar
HarDlife
Let's focus on my bigger issue. I hate my bars, I'm on set 5? I like the look from the back but hate the front. I want something around the same height maybe but without the double riser swoop look. Any suggestions?
Is it the bars you don't like, or is it the narrow glide front end? I went thru 4 sets of bars before I realized that it was the front end that was buggin' me.
I've learned to appreciate it for what it is, and that it makes the bike nimble and manueverable.
If I ever happen across a killer deal on a wide glide front end I might have to jump on it, though.
Old Jun 19, 2014 | 12:00 AM
  #146
Spanners39's Avatar
Spanners39
Originally Posted by tmanbuckhunter
What about trannys?
They ain't nuthin' but trouble....
Well HarDlife....at least you know what a Lowrider looks like with a wide and fat front end
Old Jun 19, 2014 | 05:18 AM
  #147
br549A1's Avatar
br549A1
Apparently my part isn't in stock at JP so it's going to be awhile, so I'll let you know what my thoughts are.
I've PMd many people that had similar issues that stopped posting, some gave up, some resolved. The common thing was the front mount seemed like everyone replaced and some got ok results, others it was a little better, like it was masking the problem. My VT mount 100% works well, it absorbs a lot, but somethings wrong elsewhere. I realized in searching and reading that the guys on new bikes have comp issues, the ones that do describe having my problem almost as if they are riding my bike. I then looked in the to comp and pulled it twice, didn't find anything at all. Someone in this thread suggested i look into the spring pack, and I was already, but didn't know yet what i was looking for. Upon continued searching I ran into a guy online that had my problem on a 98, but with a built motor, his was at a different rpm, but identical. I think every engine will vary slightly based on compression, wear, mods, etc. So, here's what my thought on where the weak link is.
The comp spring cover will vary on every bike, the springs will never wear equally under two different conditions. Depending on shims used to align the chain, you will have more or less clearance between the spring pack and the sliding cam. Those with more shims will have a tighter spring pack. I can tell my pack bottoms hard on the shaft leaving no tension on the spring when fully torqued, there's no preload and it appears to be too loose even though my springs aren't sagging. I have read good reports of those adding more springs into the comp spring pack, but I don't have access to one to pull apart and that wouldn't resolve my clearance issue. The solution is to try the new BDL CS24A comp assembly, it just replaces everything and I don't have to try and shim or add spacers to close up and tighten the spring pack.
Will it work, not sure. Everyone says the comps aren't bad on these so I'm not overly optimistic, but I think I've done all the research I can and need to at least give it a try at this point. I reached out to BDL to see if they wanted to team up on this experiment as if it works there's a lot of guys out there ignoring this problem, if it doesn't well, I'm in the same place I'm at now scratching my head. I do want to double check the clutch hub bearing while it's apart again, maybe spanners can tell me the easiest way to inspect it without having it pressed out.
Old Jun 19, 2014 | 06:23 AM
  #148
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I hope it works for you.
Old Jun 19, 2014 | 07:25 AM
  #149
Throttle_Jockey's Avatar
Throttle_Jockey
So assuming you have the outer primary off. You can check the hub for loose rivets by engaging the clutch (wrap a bungee cord around the handle to hold it) and shake the basket to feel for movement.
You previously stated you checked the splines and bearing I believe ?
Not saying it's your problem , but if the rivets are loose they can easily be fixed. I have peened/punched them with an air hammer before then spot tacked (welded) the gear side of the rivet.
Also have replaced them with grade 8 5/16" bolts and machined the heads/nuts down for clearance inside the basket/gear . I know in most eyes this isn't a proper fix , but is has held for 20-25k pretty hard miles with no noticable vibration.
Old Jun 19, 2014 | 09:20 AM
  #150
br549A1's Avatar
br549A1
It's not apart now, I'm riding it until the parts come in. I refuse to leave it apart, if it comes apart it has to go back together the same day. That's my rule!
