Evo shake
Old Jul 16, 2014 | 03:01 PM
  #381
Spanners39's Avatar
Spanners39
Cut a notch into the race, in such a position that with the trees on the floor you have the notch facing upwards. Get a BIG, SHARP chisel and smack into the notch with the chisel at 45 degrees to the radius of the race (wear safety goggles) and use a BIG hammer......that will shift it as it will crack the race and you can pull it off.
To soften it up before using the chisel I recommend showing it a picture of Chuck Norris....
Old Jul 16, 2014 | 03:23 PM
  #382
Son of PMS's Avatar
Son of PMS
OMG! Put the eyes of the Ranger upon it? It'll likely jump out on its own and run away!
Old Jul 16, 2014 | 03:38 PM
  #383
br549A1's Avatar
br549A1
Stem up cut the race vertical right? I did that with the stem races they never cracked I had to cut chunks out until it was loose enough to pop out. This one better crack the rain stopped it's time to ride
Old Jul 16, 2014 | 06:48 PM
  #384
br549A1's Avatar
br549A1
That race came off in 5 minutes, I did the fall away but it feels super light steering now, it's not loose I don't think. One way was easier to fall than the other. I wish there was a torque setting to just tighten the bolt to.
What keeps that bolt tight there's no lock washer or anything?
Old Jul 16, 2014 | 09:18 PM
  #385
WP50's Avatar
WP50
Dang Ok the adjuster nut is under the top tree, get it set and when the top tree goes back on (after adjustments) and the stem nut is tightened it will lock the adjuster nut in place. Kinda like a jamb nut using the top tree as a big washer if you will.
The manual on my 97 EG puts the stem nut at 55-65 ft lbs, the adjuster nut is tightened till you get the correct swing pattern. Gonna take some playing time to nail it down.
Least that's how mine is set up
WP
Old Jul 16, 2014 | 09:40 PM
  #386
br549A1's Avatar
br549A1
I have an fxdl no adjuster nut
Old Jul 16, 2014 | 09:58 PM
  #387
WP50's Avatar
WP50
Dang Wish i knew what to tell ya
Google?? WP
Old Jul 17, 2014 | 01:54 AM
  #388
Spanners39's Avatar
Spanners39
Top triple tree has a pinch bolt at the back to keep the nut tight.
Old Jul 17, 2014 | 04:58 AM
  #389
br549A1's Avatar
br549A1
I meant the top bolt. Just loctite? I tightened the clamp bolt at the back of the clamp
Old Jul 17, 2014 | 05:17 AM
  #390
Throttle_Jockey's Avatar
Throttle_Jockey
If the clamp bolt is torqued the stem bolt will be fine
