04 electraglide wont start?
Old Nov 6, 2012 | 03:35 PM
prospeed69's Avatar
prospeed69
Stage IV
Default 04 electraglide wont start?
i have a 04 electra glide and was riding with no problems and it just shut off like i hit the kill switch. and now wont strart. it turns over and i can hear the fuel pump cycle and has fire to the plugs. any idea's??
Old Nov 6, 2012 | 04:18 PM
Fastrider124's Avatar
Fastrider124
Check your fuses for the fuel injection, if everything else is there, spark, cranking, fuel pump runs, most likely it popped a fuse. If it did, check wiring connections, in fact the one that mounts on the rear of the throttle body is known to cause problems due to a loose connection. Fastrider 124
Old Nov 6, 2012 | 04:26 PM
prospeed69's Avatar
prospeed69
Stage IV
ok thanks! i will check
Old Nov 7, 2012 | 03:15 AM
95custmz's Avatar
95custmz
Check your sensors, also. In particular, your crank position sensor & your heat temp. sensor.
Old Nov 12, 2012 | 08:28 PM
prospeed69's Avatar
prospeed69
Stage IV
Default still no start!!!
evrything checked ok so i took the fuel line loose all turn the key to let the fuel pump cycle and it makes noise but not building any preasure so im guessing i have a bad fuel pump.....:icon_quest ion:
Old Nov 13, 2012 | 02:15 AM
95custmz's Avatar
95custmz
Try pressure testing your fuel pump. Also, here's a link:http://www.harley-davidsonforums.com...fuel-pump.html. Check out Schmidty's comments
Old Nov 28, 2012 | 05:22 PM
prospeed69's Avatar
prospeed69
Stage IV
fixed it!!! the fuel line came loose inside the tank. the clamp they use is a cheap crimp style so i put a good screw clamp one on. thanks for all the advice.....
Old Nov 28, 2012 | 09:13 PM
95custmz's Avatar
95custmz
Cheap fix!Glad you resolved the problem.
hotdotdog
Electrical/Lighting/Alarm
Oct 24, 2023 05:26 PM
2013superglideseattle
Milwaukee Eight (M8)
Jul 7, 2019 04:49 PM
sledbum
Feb 11, 2013 06:18 AM
blue dingo
Mar 16, 2012 10:07 AM
07bagger
Jun 19, 2011 09:22 PM
