Po563 -HELP
Old Apr 2, 2017 | 04:47 PM
Oldgreazer's Avatar
Oldgreazer
Default Po563 -HELP
i have an 07 Heritage, and I got a ck. Engine light yesterday. Bike was not idling good. Made it home and checked codes po563 came up. I have read this is high voltage issue. It was suggested to check battery voltage while idling and at 3000 rpm. The highest reading I get is13.5 volts . I cleared code and rode bike about 10 miles. It runs fine but when I brake to stop, engine light comes back on . Anybody else had this happen? NEED HELP.
Old Apr 2, 2017 | 04:52 PM
TSheff's Avatar
TSheff
Voltage Regulator - Rotor - Stator
There is a troubleshooting procedure to determine the issue.
How much experience do you have and do you have a good DVM?
A Member - RIPSAW - may weigh in on the issue.
Follow his instructions.
In the meantime I'll try to find an older thread of mine which will help.
https://www.hdforums.com/forum/softa...no-luck-2.html
Old Apr 2, 2017 | 05:12 PM
Oldgreazer's Avatar
Oldgreazer
Thanks for the quick reply .i failed to mention this all started when a bee struck my hand and let go of throttle . Engine back fire once . The rough idle started when I came to next stop.
Old Apr 2, 2017 | 05:19 PM
Oldgreazer's Avatar
Oldgreazer
Sorry I didn't answer you ? Yes I have a fluke Meter as I am a/c tech . Better on heat pumps than Harley,s
Old Apr 2, 2017 | 05:22 PM
TSheff's Avatar
TSheff
Open the link to one of my older threads.
There are detailed troubleshooting links and RIPSAW's procedure is pretty thorough.
Old Apr 2, 2017 | 06:20 PM
Jackie Paper's Avatar
Jackie Paper
TSheff has a whole lot more confendence here then he should..
Lets do the simple stuff first... How many miles, how old is battery, had any previous problems? Does it have a tuner?
Sounds like correct DC voltage.. However, ignore idle since it will be low usually and the normal is 2000 rpm in ever manual I have looked at.
However, just snapping the throttle off like that leaving a lot of fuel with no air to pump thru exhaust which will pop. (why the went to the electricial throttle by wire system..it would open a little to allow some air)
Lets make sure both cables on battery are tight and after charging with a maintance charger a few hours till light is off, turn bike on so head lights come on to kill surface charge and turn back off and check battery voltage.
Old Apr 2, 2017 | 06:42 PM
Oldgreazer's Avatar
Oldgreazer
Thanks Ripsaw for responding. Bike has 37k , tuner from Fuelmoto, Big Suker, Bassani RoadRage 2/1 exhaust, battery is less than 6 months. I have checked battery cables and are all tight. Also checked IAC to be sure it was clean and moving freely . I will put tender on tonight and check voltage tomorrow evening. Only problem I had was replaced iac 2 years ago
Old Apr 3, 2017 | 05:43 PM
Oldgreazer's Avatar
Oldgreazer
PM sent
Old Apr 3, 2017 | 08:33 PM
Jackie Paper
Will post back my thoughts later if OK with you and if others are interested...
Old Apr 3, 2017 | 10:53 PM
TSheff's Avatar
TSheff
Yes. That's how people get information and learn. Very few problems are unique and these threads help many.
