Battery problem
"CLICK"
Went to try to start it again, and this time, the instrument panel would not turn on when I turned it on.
So I ended up pushing it home about a half a mile.
Once home, I checked the fluids, fuses, gas, and spark plugs, and everything was good. The oil was at the "full" line, but I doubt that had anything to do with it.
I disconnected the battery completely, and once it was reconnected, it started up. I rode it around for a few minutes, shut it down and started it back up... no problems.
This morning, my wife asked me if I had tried to start it, and when I went to start it, I heard the "CLICK" again. Same as yesterday. I disconnected the battery, and reconnected, and it started back up. I rode it around, shut it off, and restarted it, no problems.
My question is.... Could this be a battery charge problem? I don't understand how disconnecting and reconnecting the battery would fix anything, but it seems to work. I am afraid that once I ride it somewhere, it will die, and I'll be stuck..
PLEASE HELP!!!
-John
I´ve had a similar problem, and the cause was one of the bolts of the regulator that was unscrew and did not connect correctly(ground), when the bike was stopped it didn`t start, but conecting battery again it start. When i rode the bike the bolt moves and in the next start it didn`t fire. I solve it screwig the bolt and I check all the bike to see if there where any other unscrew. I dont know if this can help but it appears to be something similar...
P.D: Sorry for my english...I don´t practice too much...
- Checked all connections, found nothing loose
- Bought battery tender, charged to 100% and found same problem
So next step, take it back to the dealer to find the problem. I will update once I figure out what the problem is.
Thanks again!
The wires coming off the battery were loose. I was checking the tightness of the wires coming off the battery with a phillips-head screwdriver, and with the screwdriver, I could not tighten the bolts any further. My friend came over and used a ratchet to tighten the bolts, and the problem was gone.
This is my first HD, but I have been riding dirtbikes my whole life, and I really felt like a "new guy" when that happened.
So, lesson learned.. I apologize for wasting you guys' time!
John
John
When I got home, I checked for engine codes but there are none. Very odd. Then someone said to check the battery terminals. Sure enough, they were about half a turn loose. I'd tighten them down and not have a problem for months. It'd happen again a few months later and it'd be the same thing.
I've gone to using a split lock washer and/or blue locktight. I haven't had the problem in a while.
