Power Vision Information Thread
Old Aug 4, 2011 | 12:27 PM
  #1111
iclick's Avatar
iclick
Originally Posted by fuelmoto
On your O2 sensor you can splice the wires however you cannot solder them
I'm a solder kinda guy and traditionally use solder and heatshrink for all electrical connections. So what's the best way to splice the wires together that would make it secure? Butt connector?
Old Aug 4, 2011 | 12:34 PM
  #1112
iclick's Avatar
iclick
Originally Posted by captdave221
I finally decided to set all a/f at 13/1 and just use the WB sensors to tune with as I was jumping back and forth in VE changes at 2200 to 3000 rpm and 40 to 60 mpa. I want to get the area where I cruise the most tuned 1st along with the idle and worry about wide open when I can get on a dyno.
So was the "jumping back and forth" happening when you were tuning with the NB senors? Could you describe what's happening in more detail?
I'd like to know if everyone is having good results homing in on a tune using the WB sensors and the LT. Surely someone besides Dennis and I are tuning with the AT-100 Pro.
Old Aug 4, 2011 | 04:09 PM
  #1113
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
I would use butt connectors and heatshrink, I have has to do this a few times here
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Aug 5, 2011 | 07:02 AM
  #1114
JustDennis's Avatar
JustDennis
There is a new version of WinPV and new firmware for the PV available this morning. Don't know all that is in it yet. You should be sure to update all of them as they work together.
WinPV version 1.0.44.914
Firmware version 1.0.6-904
Log Tuner 1.0.13
Old Aug 5, 2011 | 09:42 AM
  #1115
JustDennis's Avatar
JustDennis
Iclick
I will tell you that I have gone back and forth between the stock O2 sensors and tuning with the WB senors several times. I even tuned with the WB sensors then tuned with the O2 sensors on top of that for the cruise range. I have found that the stock O2 sensors seem to be affected more by external variables like temp. The VE table values seem to "bounce" a little more on tuning runs. The WB runs have some variation but seem more stable, at least on my runs that is. The stock O2 sensors provide a good tune but I lean towards the AT WB sensors. Plus you can tune a bigger range with the WB sensors as you know.
What I have found that seems to work best for me is tune with the WB sensors and "finalize" the tune. Then I load that calibration, re-install the stock O2 sensors and let them work in the closed-loop area of the calibration. Lately I have taken a tune finalized as above and taken it out of closed by reducing the AFR to 14.1 in the cruise range. It has been in the upper 90s to 100 here for the last several weeks and that changes seems to help my engine temps.
I prefer the AT tuning with WB sensors but the stock tuning works too.
Old Aug 5, 2011 | 11:47 AM
  #1116
Morris9982's Avatar
Morris9982
Log Tuner 1.0.13
I downloaded this update this morning. One thing I saw was that the new firmware includes the trip page discussed earlier. It shows Trip A and Trip B mileage and MPG.
Now I need to decide if I want to mount the unit on my bike so I can was the gas mileage...
Old Aug 5, 2011 | 05:37 PM
  #1117
CrusingHarley's Avatar
CrusingHarley
Iclick,
I have an electrical background and personally despise butt connectors, I never use them. I would strip the two wires back and use a lineman's joint. Solder and then cover with heat shrink. If the splice is open to the elements, you can get heat shrink that will seal water tight. Another option would be to install a quick disconnect connector that is weather tight, like the end of the PV cable that plugs into the bike. I hope this helps.
Old Aug 6, 2011 | 05:04 PM
  #1118
iclick's Avatar
iclick
Behold, LT v1.0.14 is out.
Old Aug 8, 2011 | 08:30 AM
  #1119
JustDennis's Avatar
JustDennis
Thumbs up
DynoJet has added a News section that gives you some good information. You can find it here http://www.dynojet.com/powervision/p...sion-news.aspx
Particularly interesting is the new features listed. Some of them have been requested here. I really like the change indicator and am testing the exit PC link mode. I really think that will be helpful. To exit PC link mode, click on the Powervision dropdown, select Diagnostic/Test Function then select Exit PC Link mode
quoting....
"Many new features are now available for your Power Vision. Please use the Update Client to acquire the latest software, firmware, and tune database. Some of the new features include:
Fuel Mileage Trip Center – allows you to correct Distance, Fuel Used, and MPG channels to yield accurate MPG readings.
Added Smooth and Interpolate functions to WinPV
Added Undo function to WinPV
Added “Revert to Last Loaded” function to WinPV
Added a visual indication to identify parameters that don’t match when using the compare feature. This offers a quick, easy way to identify where the tune has changed.
Added “Exit PC Link Mode” function to WinPV. This will allow you to enter a few menus, such as “Datalog” without the need to have the Power Vision attached / plugged into the bike. No more draining the battery to assign channels to gauges
http://www.dynojet.com/Blog/?p=80
……..and more.
Old Aug 8, 2011 | 09:02 AM
  #1120
CrusingHarley
Removed, error on my part.
