Power Vision Information Thread
Perfectly acceptable to do tuning this way. The more you log and more cells you hit, the more accurate you can make your tune but it doesn't all have to be done at once. That is one of the things I like so much about the PV - it is so easy to log data. You can keep tweaking your tune as much as you like.
One other suggestion to hit more cells - try the Autotune Data logger i post about a couple of week ago. It allows you to see which cells you are hitting. I added the instructions for setting it up to the Basic instructions I put together some time ago too http://www.box.net/shared/i66qvn4xf1s2xp7fgy8v
Acel Enr
Advance F
Advance R
Decl Enl
Econ.Inst
ET
Front AFF
Front O2 V
Gear
IAT
Idle Set
INJ PW F
INJ PW R
IONQ1
MAP
Rear AFF
Rear O2 V
Rich/Lean
RPM
Set AFR
TP
TripA.Econ
VE Front
VE New Front
VE New Rear
VE Rear
VSS
And the front and rear Spark retard (I don't remember the name in PV)
Get about 10 meg worth of data as you can see on the PV screen. Once you have those logging, I can show you a few tricks.
AW
http://www.box.net/shared/qu46vr2y7tg3yp6tmft7.
Ed
I found 3 different versions of how to use the log tuner to tweak your settings. One is on the Fuel Moto (Link) website, one that JustDennis (Link) created, and lastly the WinPV User Guide (Link) from the DynoJet website. My question is, which is the better version to use? There are a lot of similarities in each version, but there are also a lot of differences...especially in the WinPV user guide.
The DynoJet manual is a very detailed look at the software and PV with screen captures that steps in the setup and tuning process in great detail. It tells you how to do a lot of things but doesn't really tell you why or tie them together. It is intended as a reference manual for the PV and software. Many times it tells you all the things you can do but not why they should be done or in what order. I have suggested and requested that at some point DynoJet publish a "How to tune your Harley with PV" manual.
FuelMoto's guide is more of a how to setup and do tuning guide. It is very good and has much of the material that can be found in the one I did. It is a basic setup and tuning guide.
JD Basic Instructions - I compiled this from various sources at the request of some of the folks on the forum here. It is a simple How-to guide combined with some common questions that folks here were asking. I added some Tips and Tricks along the way plus some unpublished features from DynoJet that are in Beta testing. It is an informal compilation of the information that can be found in the manual from DynoJet, the instructions from FuelMoto and the information found in this thread and others on the forum plus some information garnered from personal experience. These instructions are a work-in-progress as we find more information thru our questions here and DynoJet adds functionality to the PV.
Each of these has its own usage and folks have found each of them helpful. I would recommend that you use the DynoJet Manual to become familiar with WinPV, Log Tuner and the PV, use the information from FuelMoto for initial install and setup and read the instructions I wrote to help summarize the tuning process along with tips and tricks to help with tuning.
Hope that helps. If you have any specific questions, someone here is sure to help.
If you log "extra" channels in addition to the channels needed by the logtuner software, does it affect logtuner results or does logtuner just ignore the additional channels?
Also, I noticed on your new instructions that VE front and rear are needed for later versions of logtuner. I am using the newest version of logtuner on the DJ website. Does that mean that I need to Add VE front/rear to my signals list in addition to the 11 signals that I am already logging?
If you are getting VE changes with the log data you are using, you can continue. If you stop getting VE changes, add VE Front and Rear and see if that resolves the issues. Or you can add the channels to what you are logging, it seems that DJ is using that information in some circumstances.
AW
2. When using the 319245 code, does it log all of the required signals for logtuner to calculate a new value file? And is there any advantage to using the code over manual entry of the signals?
3 The following is from the Fuel Moto instructions:
"PV Log Tuner uses only certain data and also has specific filters, however for the quickest results it is recommended that you disable Accelerator Enrichment, Decel Enleanment, and PE Fuel during the log tuning process. To disable AE and DE you can go right to the AE/DE Multipliers and change them to 0, and for PE set the PE Enable RPM above 6200"
Are these changes made to the calibration then flashed to the ECM prior to data logging, or are these changes only made to the calibration stored on the computer and then reset prior to copying to the PV for flashing?
Sorry in advance if these were already answered in prior posts.
PS. Thanks for the answers and help Dennis
With the PV connected to your bike and ignition and run switch on, from the main menu screen, select "Settings", then "Enter Code". On that screen enter pin 319245 and select Save. Once the screen comes up, you can press start log just like you do on the gauges screen to begin data logging.
Is the code remembered by the unit or does it need to be reentered each time you plug the unit in to the bike or each time you start a new log?
Michael
