Power Vision Information Thread
Old Feb 4, 2012 | 10:08 AM
  #1701
Nicky Pass's Avatar
Nicky Pass
Are you guys that are data logging and tweaking Fuelmoto's maps really gainf anything? I've heard that they are pretty spot on when it comes to making maps. I guess if you are beyond a stage 1 I could see tweaking....but I'm Hoping for a flash and go.
Old Feb 4, 2012 | 10:15 AM
  #1702
Keithhu's Avatar
Keithhu
Picking my bike up today (APES!), thats my plan for now, you could probably dial it in a smidge better here and there, but I doubt you could feel that.
Old Feb 4, 2012 | 10:50 AM
  #1703
stro1965's Avatar
stro1965
I'm a tinkerer. Can't help it, it's a sickness. I thought my bike was running pretty good with the Fuelmoto map and probably would have been satisfied until I looked at the data logs and saw all the spark knock events, gotta try to do better in that area.
Old Feb 4, 2012 | 01:22 PM
  #1704
Yardstick's Avatar
Yardstick
Originally Posted by stro1965
Quick question.... Now that I have created a new map based on changes made after 3 data log runs, when I do more data log runs and want to make further changes do I need to make a new value file based on the second map? Or does that original value file work for all future changes?
You will need to load the modified map into your ECM and make a new pvv file with the values of the modded map as the pv will be running datalogs on the updated map. You continue that process until your VE tables have very small changes. Then quit unless you change something else that affects airflow.
Old Feb 4, 2012 | 01:52 PM
  #1705
stro1965's Avatar
stro1965
Thanks!
Old Feb 4, 2012 | 04:30 PM
  #1706
Buckinfitch's Avatar
Buckinfitch
he can also save his current unaltered map(s) from FM to go back to if created modified VE tables map is bad, correct?
Old Feb 4, 2012 | 04:46 PM
  #1707
Keithhu's Avatar
Keithhu
Correct.
Old Feb 4, 2012 | 08:01 PM
  #1708
skratch's Avatar
skratch
Originally Posted by Mbarz
I have been doing my data logs using the Mega Log Viewer, which works okay. It has just expired, since it was free. I was planning on getting the excel program to use with my PV Log Tuner. And I wanted to know which excel program is everyone using, wanted something basic so I can chart my data logs. I am not familiar with excel and do not use it. Just would use it for my PV.
if you don't have ms office (excel), and don't want to spend the money on it, you can try openoffice (http://www.openoffice.org). it will read, and edit, ms excel spreadsheets, and it's free.
Old Feb 4, 2012 | 08:16 PM
  #1709
Keithhu's Avatar
Keithhu
Flash went fine, I think. It asked me a couple of weird questions - first one warned me not to choose it unless I'm an experienced tuner.
OK, no to that one, LOL.
The other question I'm having a hard time remembering - do I want to load the associated trim values, or something, so I answered 'yes' to that one.
I wont be able to get on it until Monday afternoon.
Old Feb 5, 2012 | 07:53 AM
  #1710
stro1965's Avatar
stro1965
I don't remember seeing the first question but you answered the second one correctly.
