Power Vision Information Thread
Old Aug 6, 2012 | 07:18 PM
  #2801
jbrushoe's Avatar
jbrushoe
Originally Posted by JustDennis
Send you an email
Thank you
Old Aug 6, 2012 | 07:27 PM
  #2802
bohica48's Avatar
bohica48
Okay, after many tuning runs I have my VE’s dialed in. My last tune I decided to adjust the timing to see if I could get a little more performance. I added 3 degrees of advanced timing per Heatwaves post #2169 where his tuner suggested “advance the spark in both cylinders across the entire map by 3 degrees EXCEPT the 100KPa column and the upper left corner (750-1500rpm and 0-50KPa). Essentially the spark advance should remain unchanged in the idle and start area and should not be raised above 30 in the 100KPa column.” He also suggested that if there was no spark knock try advancing another 3 degrees with the same caveats until knock is detected or heard then dial back 3 degrees.
So far I have made a couple of log runs with 3 degrees of advanced timing that resulted in zero spark knock, also seemed a little more responsive. My question is what is the downside of advancing the timing this much? I have heard that HD is pretty conservative on timing with a stock tune.
Forgot to mention that I have been running off of a Fuel Moto map that was loaded on the PV.
Old Aug 6, 2012 | 08:14 PM
  #2803
cbrown@woods.net's Avatar
cbrown@woods.net
Send you an email
Include me as well please.
Sent a second email earlier today to DJ due to non-responce.
Old Aug 6, 2012 | 08:51 PM
  #2804
JustDennis's Avatar
JustDennis
Sent you an email at your userid address. Let me know if you got it. Good luck.
Old Aug 7, 2012 | 01:07 AM
  #2805
cbrown@woods.net
Yes, thank you.
Old Aug 7, 2012 | 08:52 AM
  #2806
Sam2010's Avatar
Sam2010
I admit not very interested in tuning with the the beta version right now at this point. I have everything figured out the way it is and bike is running pretty good. I am sure it does have some features I am interested in. If the beta version is implemented will it still be optional to tune the current way? I have to think you could still interface with the PC. it only makes sense.
Old Aug 7, 2012 | 09:04 AM
  #2807
JustDennis's Avatar
JustDennis
Yes the new version doesn't take anything away, it just adds several new features - one of which is tuning without using a PC.
Old Aug 7, 2012 | 09:33 AM
  #2808
dballew's Avatar
dballew
Anyone know when software update is being released.
Thanks
Old Aug 7, 2012 | 11:08 AM
  #2809
wfayard's Avatar
wfayard
Yep I would like to try the new beta software as well, could you let me know where to get it.
Thanks
Old Aug 7, 2012 | 11:20 AM
  #2810
JustDennis's Avatar
JustDennis
Thanks
on the way
