Power Vision Information Thread
Here's the easiest way to deal with timing. Set up a .PVV just like you would for a Log Tuner run. Save whatever you need for your cal. EX: TPS cals save fr and rr VE, AFR, and fr and rr spark. Go datalog a nice ride. Then use log tuner. Take the check marks out of VE fr and rr so it doesn't dork up your VE work. It will just make changes to your timing tables. It will only import your timing changes. Much much easier than trying to analyze a datalog to determine exaclty where the knock occured. It's a tad difficult to determine EXACTLY where to pull timing based on datalog. So, let the Log Tuner do it for you. Just remember to take the check marks out of fr and rr VE's.
thanks... i think i will do that, in part just to get a little more comfortable with log tuner and also for the timing :-)
question
does anyone know the difference between simple csv and pro xy , if so what are the pros and cons between them ?
request
i have a 2011 softail drive by cable 96" new exhaust (2-1) and intake, no cams, almost stock bike and i would like to see some modified spark tables for similar types of builds/bikes.
i know your spark advance may be different from hers and may be different than mine....just looking to see how much of a change some people may have from the spark tables they started with.
info about exhaust (especially if it is 2-1) is nice but if anything i would be more interested in the grade of gas used.
thanks for your time and assistance
The seat of the pants Dyno and just overall feel and sound of the bike is fantastic right now. it seems to start a little harder than it did previously. Is there a way to fix that?
Here are my VE tables.
This IS easier on a true Lambda tune from a touring bike as opposed to half lambda like on new can bus bikes, or AFR tunes from 2009 and back.
That is trying to get the correct VEs as low as possible.
Lower the idle to 800 rpms. Gather data, at idle for that 800 rpms. On a AFR DBW bike? That will be the 5% column most times. Then... see if you can use second gear and the brake and clutch and TRY to get... say the 7% and even 10% columns at that low idle.
Next is to put the bike to the regular 1000 rpm idle. (I set all bike to 1000 rpms at normal idle and the lowest I would EVER go is 960). With the bike all nice and hot (200*), collect data from idle, looking at the histogram, try, while sitting on the side stand, getting another cell to the right, or even two.
Take a ride to gather data. Using second gear, the brake and clutch... watch the histogram and TRY to get as many cells to the right in the 1000 and 1125 rows. No need to use heavy braking or clutching. One is looking for a balance that ruins neither to get as many EASY columns in those rows to dial in.
The further up in RPMs one gets the more cells to the right one should REALLY try to get. 1500 rpms should be filled completely, as also the 1750 row.
This IS hard tedious work. But it IS what I take time with on a wheel.
When done, one should be able to be in 6th gear at 1500 rpms and whack the thottle and NOT get a 'bog', a rattle, bucking, popping, etc. It will NOT ramp RPMs all that quick, but if the very bottom is tuned and the VEs are correct... the bike should climb out with NO drama.
When I talk about 'nice manners' THIS is one of the things I tune for to make a bike ride nice..... And... I tune for a completely nice bike to ride. that IS always my goal. NOT 'numbers' at all. One does NOT ride numbers, one rides a bike and a bike should NEVER buck, pop, sputter, cough, stutter, etc. If... if a big cam comes into play, to get tuned, sometimes it is simply impossible to get a bike to simply pull out, by itself, by slowly releasing the clutch with NO throttle added. ANd... you guys think of this: at idle, when you release the clutch, does the engine spped up? Nope! And THAT is THE reason to lower the idle speed and gather data, adjust the VEs at 800 rpms for a bit. Nice and SMOOTH is whats happening.
Right now? I have my own personal 120r tuned to pull out nice at about 1600 rpms. BIG cam and BIG cubes with BIF throttle body. ALL of this hurts gathering data down low... more overlap makes it HARD.
I NEED to work it some more to TRY to gather VEs at the lower RPMs. Big assed 102r? Makes the whole dyno shake like a quake at such low rpms. But... if one sneaks from good cells and collects even one cell at a time, it usually SHOULD pull in.
There, I gave up a GOOD tuning secret for you, Jim. It DOES fit into your own strategies, too. DIYers SHOULD strive to get a nice mannered bike. I know that most will NOT take the time, but for those that will... it IS whats happening.
IMO ... Dynojet has done a remarkable job in creating a tool to safely tune these bikes without a dyno & an expert operator/tuner. I do feel they could have done a better job explaining the Autotune process for the average enthusiast, the order in which things must be done isn't mentioned in any manual from what I've read. But maybe they intentionally left this grey area open to support their retailers/wholesale customers such as companies like Fuelmoto.
Just my 2 cents ...
Ry
this is a very helpful forum and many experienced people here will try to answer questions when they come up but for those of us who like to do a little reading along the way you will find reading pages 300 and up makes more sense the more you start to understand things.
i will be reading those pages once again as i am starting to understand things a little more and i find my brain glossing over things a lot less :-)
