Power Vision Information Thread
At least that has been my experience.
Anyway, I've looked at maps from DynoJet, FuelMoto and S&S and all seem to use different "Throttle Gear Transition" some 3 some 6. But I've also see "Throttle Blade Control (Stage I)" and "Throttle Blade Control (Stage II). I understand you don't want the Drive By Wire to be TO sensitive but I'm wondering what some of y'all are running and possibly why you chose that setting and if it's helped in your quest for a little smother / faster throttle response.
I started reading this thread from the beginning when I first got my PowerVision and can't recall ever seeing this area of the map discussed.
He has a 2009 RK sage 1 tuned with SERT. He is happy with the tune and has no reason to change it.
He wants to know can he put a Power vision on his with out effecting the tune and use the other function. I Have no idea ,it seems it should not make a difference.
Does anyone know for sure. Do worry about waste of money if you own a Motorcycle you get use to it. He not hurting for cash.
"For me, I found that adding the Pro tuner/WBs made a (significant) difference in my tune; and I ended up with a totally OL tune.
It runs better, smoother, cooler, more responsive, and averaged over 2400 miles right at 40MPG; including a lot of serious throttle thrashing while tuning and two up touring."
Regardless of either 'sniffing' or real dyno tuning, what I found in my experience is accurate as far as it goes; and to this point (final dyno tuning to come later this spring) just employing the DJ WB tuning, the results I reported above are what I experienced.
I did not state it was the best possible... just that what I have found this far.
Having gone through a couple of major rebuilds on the last two HDs with dyno tunes, I agree--there is no substitute. However, short of that being available to many, as you have attested previously, a very satisfactory result can be achieved using the PV as outlined and refined by several on this forum.
Cheers Jim... your assessments and comments are always welcome. JD...
They flashed it with a canned map from Dynojet to match my AC and pipes.
Not my forst HD or 103 so I know how the thing should run. It was flawless.
I added the fuel Mot 2-1-2 headers at 2000 miles and re-flashed it wit Fuel motos map. Again painless and flawless.
reading up on it I saw there was so much more It could do. Mounted it and started playing with it. More reading I ran a few auto tunes. It took some messing around but ended up with a good run and a tune that increased Fuel mileage and still ran fine.
The power vision is a great tool it can be a simple flash and forget rt a great tool to experiment with. Simple or complicated depending on where you want to go. The other function it has allow you to display information you may want to see.
Power vision IMO is well worth the cash and time. I can ride with the best of you. Wrench on basic stuff any time . But a tuner for EFI bike I am not nor do I wish to be. The Power vision filled that knowledge/skill gap with a bit of home work and time.
