Power Vision Information Thread
Yes, my timing is aggressive and is why my AFR probably looks different than most. I think the hottest I have seen on ET was 275 and I pulled over and added fuel to the area and was able to bring it down to 255. I had knock too when I first started with the map and it was around the 3-4000 range and about 75-90 MAP, hence the dramatic retard in those ranges.
If it were me, I would turn on logging and go make a couple runs. Some of mine where a hour before I could find just the right conditions. I also did a combination of cruise control and manual. With the log file, you will see exactly where the knock events happen, the timing range and the retard needed to correct the issue. Without the log files, you really are just getting in the range of knock. I was surprised that knock was happening in areas outside of my mental notes where I thought there happening.
When I was doing my tuning, I would take my laptop with me so that when I found a road area that caused a knock or I didn't like the acceleration up a hill, I could pull over, make adjustments and load a new tune and then run the same road a couple times.
One time, I was on highway 730 and had made 4 runs in a 5 miles stretch. Didn't notice at the time but there was a local sheriff radaring traffic. I went by him several times and he finally pulled out and pulled me over thinking I needed help or had lost something on the highway. We talked a bit about what I was doing and even made the comment that if I needed to do a WOT run that I could and he'd understand but just keep it under 100 when there was no traffic. He's a biker too. I didn't take him up on his offer.
Where are you located in Texas? If you are close, we can make a plan to meet up and make a couple of runs.
I will definitely get out and do some logged runs and then see what I need to do. I'm down in Austin, so maybe one of these days we can meet somewhere in the middle. Bringing the laptop along is a good idea. Pretty cool about that cop. I'm always worried I'm gonna get a ticket whenever I'm out doing tuning runs.
I'd call the dealer and take it back to them since they did the install.
I noticed there is no original tune , just the one the dealer loaded
Thanks guy
FB
I just received my PV2. I installed all of the software, updated all software and firmware. While installing the PV the screen got nicked ( the plastic cover). After connecting to the bike I was able to download a tune, and started setting up the gauges. I got part of the way through, and the touch screen stopped responding. I turn the bike off and back on, and the PV is still on the gauge setup screen and locked.
Also I thought the instructions said that the stock tune would be down loaded to the PV while installing a custom tune. I reconnected the PV to my computer and the stock tune was not listed. Any ideas?
Also does the on/off switch do anything? It does not respond to anything, short duration press, or a longer duration press......nothing. Thanks for any help.
From Jamie regarding the original tune:
When you connect your Power Vision to the WinPv software it will automatically prompt you to save a copy of your original binary .stk which will be saved in Documents>Power Vision>Original Tunes, it will continue to ask every time you connect if it does not see a copy. If you would like to view and work with the original tune in PV format on the device you will go to Program Vehicle>Load Copy>Copy of Original and you will then place it in a slot in the tune manager, you will then connect to the WinPv software, click Get Tune and select the appropriate map from the tune manager. You can then view, compare or edit the tune.
