Power Vision Information Thread
If you buy from FM they will give you a decent starting map for your 57h cams.
I just took a look at S&S's site for ya, They used to have a lot of PV tunes, Now click on PV and it says, Coming soon. And a new exhaust disclaimer is up. Looks like they are going to do some house cleaning and removing non EPA approved BS
Glad I did NOT install them Power Tune Duals 'wink
At least DJ will still email you a custom tune file for different cams. Or FM of course, if you bought the PV from them. No dice for me though I'm stuck with DJ only. ;p
I got the 48h cams installed today, new tune file loaded and will test start / ride tomorrow.
I thought it might run out of steam up top but I was holding it WFO up through 5k rpm shift points, 4th, 5th, 6th and it was still pulling great as the speedo was walking past 100mph. that's when I let off. with a smile.
I'd expect the same good results from the 57h cam but only with a bit more compression added to the stock motor- e.g. running some .030 head gaskets. Or, if for some reason your stock motor is on the higher side of stock compression tolerances then you'd probably be ok with the 57h. For my stock motor, static compression, and tested dynamic compression after the 57h install, the 57h just bled off too much compression during operation to keep the grunt down low. this is due to the later intake close event of 42. the only fix here is to raise compression, get a 4 degree cam advance gear so the 57h's close the intake valve sooner, or get different cams that are already cut to close the intake valve sooner. I chose the 48h's because they had the better intake valve close specs I was looking for, along with the other good characteristics of a mild drop in performance cam.
For reference, the stock 103 cams have an intake close event of 30. As you close the intake valve later (larger number), the operating compression of the motor will become lower. This is ok with high compression motors and in many cases it is needed to keep operating compression within tolerable street build limits, but it can be 'not so good' with stock compression most of the time.
Anyway the 48's are staying in. Bike pulls like a monster now and it's plain obvious TQ went way up over the 57h. It's a seriously kick *** cam in a stock 103" and if the 57h is not doing it for you, give this one some consideration.
Question: Why is it that FP3 and TTS are keeping pace with building custom base tune library files for cam and motor upgrades, but DJ PV is only keeping stock or stock improved tune files in the library? Is PV going "epa friendly" only now? Anyway it was rather frustrating having to again roll my own tune and cob it together, and get help from a different tuning product's files. Not a single cam upgrade tune file to choose from in the latest PV tune DB...
For example, the TTS tune file I referenced is a current one (mt9) and is for the 2016 Softail HO 103, with 48H cams, 50mm TB, 4.3 injectors, Cycle Shack slip-ons. There are ton of other engine modified tune files in the product library. I see this same selection of performance base tune files available for the FP3.
Why is DJ not making these types of performance upgrade base tunes available for current bikes? They used to back in the PowerCommander days, if you go back and look at that library you see a ton of cool motor combos, cams, heads, etc etc..
I do like the Powervision it just seems to me there are no efforts with making a robust tuning library available or making it easy for the rider who wants to self tune his cam and engine upgrades.
Sure I got my bike dialed in- but- I sort of know what I'm doing. There is no way a average person who did not buy the PV from FM (and had their help available), could have done what I did today. And that is lame because I did not really do anything special. install cams. upgrade injectors. A/C, pipes. real run of the mill stuff.
Sure I got the new base file from DJ with 48h cam events quickly after I requested it, but that is where all help stopped. All they did was modify my existing 57h tune file only for the new cam events and sent it back. nothing else changed. It's sorta like - ok here is the requested change... good luck with that. lol
But granted there is what- one single person at DJ dedicated to helping with tune requests for the PV? that is nuts. there is no way that one tech person can help everyone or be effective.
the tune file would not have operated the bike successfully today if I had not massaged my own VE & spark tables, fuel related settings, etc. - and I had to reference another vendors product tune library in order to do that.
Not so good DJ- hope it shapes up and hope they are not cowering to the EPA / CARB regulators. DJ is after all, a mfr of some of the best Dyno machines right? And they don't have THE BEST AND LARGEST tune library for the PV? That is crazy. and stupid. ;p
That's the end of my complaint, hope it is heard and helps to make a better product. I'm hooked on the PV's TT wideband o2 tuning and real time engine operation- that is the cat's *****. fastest damn VE tuning ever, and accurate. I would not want to give that up.
Engine tested April 26 2016 prior to cam upgrades:
- Static Compression Ratio @ 9.53:1 (HD specs call for 9.6:1 stock but there is always some mfr variance) Static compression ratio remains the same regardless of cams installed
- >> Stock cams (IVC @30): 187 F / 188 R CCP, 9.11:1 Corrected (Dynamic) Compression Ratio
- >> 57H cams (IVC @38): 181 F / 182 R CCP, 8.68:1 Corrected (Dynamic) Compression Ratio
- >> 48H cams (IVC @29): 188 F / 189 R CCP, 9.14:1 Corrected (Dynamic) Compression Ratio
- * CCP's based on altitude @ sea level
