Power Commander vs other systems?
Old Aug 18, 2005 | 10:28 PM
AJSpringer's Avatar
AJSpringer
4th Gear
Default Power Commander vs other systems?
I am interested in the Power Commander and other systems. I'd liek to hear from those of you who have had good/bad experiences. Suggestions?? I own a 2005 FLSTSC w. Stage I airkit, fishtail pipes w/ Thunder Monster baffles. Trying to get rid of some or all of the popping. Plugs had 7300 miles and were running hot. Front had too much white, rear was glazed.
Old Aug 19, 2005 | 12:40 AM
HD4ME's Avatar
HD4ME
Default RE: Power Commander vs other systems?
I have an 05 Fatboy with V & H Bigshots and Thunder Monsters. Had Power Commander installed and dynoed. No popping whatsoever on decel! Runs great. Roughly 82hp and 85 fp torque.
Good luck with your decision. Guy that did the dyno likes the PCIII because of the tuning capabilities.
Old Aug 29, 2005 | 09:41 PM
TedMan's Avatar
TedMan
Hello All,
I spoke with the folks at Big City about Thunder Monsters and they were very helpful. I put on the 16 ga. dbl. brl. shotgun w/ SE and EFI map. Love the looks of the pipes, they are actually the same as V&H but come with the "quiet" baffles. I would like a little more sound, and the Thunder Monsters sound like just the ticket. One thing I am a little unsure of is the the tech at Big City told me that I would not need another map or download after I install the Thunder Monsters. They suggested I buy a type of tuner (can't remember name, not Power Commander) that doesn't need dyno, as they indicated that I may want to richen the mix a little afterwards. Any thoughts on this or anything else re: Thunder Monsters would be greatly appreciated. Thx. BTW, I have a 2005 Deluxe and absolutely love it.
Old Aug 29, 2005 | 10:05 PM
HDF Tech's Avatar
HDF Tech
Check out this section of the DIY forum https://www.hdforums.com/forumid_247/tt.htm
Old Aug 29, 2005 | 11:31 PM
Taildraggerdave's Avatar
Taildraggerdave
I just installed my new Revtech Stealth DFO to my bike. Seems like a nice unit. Install took less than an hour. The first adjustment you do to is to set the "mixture" by turning a small pot with a screwdriver. They tell you to set the engine at 1800rpm's then turn the screw for the highest idle. I gained 400rpm and the engine sounded better, smoother, etc. Going out for a test run to set everything else. No backfires or pops in the driveway when the other adjustments were set to the recommended default positions.
Old Aug 30, 2005 | 02:48 PM
TedMan's Avatar
TedMan
Thanks for the link. Techlusion is the device Big City mentioned. In your experience, how are dealers with honoring warranty as one adds more "stuff"? Thanks again.
Old Aug 30, 2005 | 07:09 PM
Taildraggerdave
That's the beauty of the Revtech/Techlusion device. It is transparent to the ECM. My bike has a 7 year warranty and I don't want to do anything to jeopardize that 5 or 6 years down the road.........There is no download for a CVO bike so no worries there. It came with the Stage 1 A/C. All I have to do is swap the stock mufflers back on and lift up the fuel tank, unplug the harnesses for the DFO and my bike is 100% showroom stock.
I ran the bike last night. Runs well with the DFO. I used the recommended settings and the bike doesn't backfire any more. Can't say that it will wheelie or anything now but I feel a lot safer knowing it's not gonna melt down. I may pull the seat and fine tune it a bit more for some additional power but I want to see what kind of mileage I'm getting on the current settings. I checked last night on the fill up and I was getting 36mpg all around mileage. I hope it doesn't get too much lower. Good luck.
Old Sep 1, 2005 | 01:11 PM
TedMan's Avatar
TedMan
Thanks again for the input. I, too, have extended warranty, and do not want to jeopordize it. One last question: how "loud" are the thundermonsters? I know its a subjective question, but compared to your stock set-up (V&H), how much louder are they? BTW, nice looking ride.
#1rocketman
EVO
15
Mar 14, 2011 09:37 AM
Frosty883
Feb 21, 2010 07:57 PM
Slick1007
Mar 15, 2008 10:53 AM
dj4016
Sep 3, 2005 12:38 AM
JBBOOKS
Exhaust System Topics
Apr 17, 2005 02:08 PM
