M8 problems
Old Mar 21, 2019 | 03:22 AM
  #1651
splattttttt's Avatar
splattttttt
OMG!
And this company brags about progress?
Old Mar 21, 2019 | 10:20 AM
  #1652
Wizardofaus's Avatar
Wizardofaus
Originally Posted by splattttttt
OMG!
Yep and that makes ya want to run out and spend 25 grand on one of these high tech marvel’s.
HD’s going down the ******* and their too frigin arrogant to know it.
Wiz Out Man 🤘
Old Mar 21, 2019 | 10:25 AM
  #1653
Wizardofaus
Originally Posted by 17rdgs
Hello I am hoping someone can tell me best place to start , I was riding heard a loud ticking sound from front cylinder loss some power and pulled over. Had it taken to dealership they will not work on under warranty due to powder coating. They said the front has compression of 70.
My road glide 3000 miles on it, about 100 since powder coating. I took off rocket heads and push rod tubes. The bike will be delivered back here tomorrow. Is there a test I can do to narrow down possible cause or do I just need to remove rocker cover and see if I see a broken rocker and bent rod?
Thank you for any advice
Mmmmmm So she was all good then ya got powder coating and then it **** the bed after a 100 miles huh ?.
Maybe a few pictures of the powder coating or a better description other than ya had it done as to what and where might help.
The most logical thing is most likely the cause of the problem.
Wiz 🍻
Old Mar 21, 2019 | 11:38 AM
  #1654
Max Headflow's Avatar
Max Headflow
If you removed rockers to PC, you probably cracked a rocker tower. Not HDs fault technically tho they could have made the towers a little beefier.
Old Mar 24, 2019 | 07:28 AM
  #1655
Jackmack's Avatar
Jackmack
Stage III
Default M8 issues
Got a 17 m8 new, did stage 4, at 10k miles engine seized. I have heard that this is not uncommon; question is, have the problems been successfully addressed in the 2019s?
Old Mar 24, 2019 | 07:49 AM
  #1656
splattttttt
wouldn’tthere be motor oil shootint, not dripping out off the top end if this was the case? Not sure if this was already mentioned? But if it indeed is gushing out motor oil, then you’re probably right
Old Mar 24, 2019 | 08:43 AM
  #1657
Max Headflow
Where is the oil gonna come out from?
Old Apr 7, 2019 | 10:01 AM
  #1658
tomcat3b's Avatar
tomcat3b
My 2017 M8 has 10k miles and not one single problem.
Old Apr 7, 2019 | 11:50 AM
  #1659
Wizardofaus
Does it have any sort of stage kit installed ? ,
If not that’s the reason why.
Ride safe man
Wiz 🍻
Old Apr 7, 2019 | 11:54 AM
  #1660
Wizardofaus
Originally Posted by FatBob2018
The migrating transmission fluid issue is solely related to touring bikes. They have a hydraulic clutch, the Softails don't.
As for sumping, while it is technically possible for a Softail, it seems to be much more unlikely for a Softail to sump than for a Touring bike. It can and has happened (we have had exactly one report here of a Softail sumping in the 1.5 years they've been available) but it doesn't appear to be nearly as common on a Softail.
Well they had a hydro clutch recall awhile back, was this really the start of the sumping problem in another guyse ?
( Just for those that are bothered with this )
Wiz Out Baby 🍻
