M8 Engine Temps
I said all of this to say that I quit worrying about it (or at least trying not to) I changed the screen on my PV to not show temps and I guess if it melts down I will worry about it then...
I asked why the didn't tie into the ECM EITMS, that was their response - added cost.
So if your build is making the engine run hot on the road, then a oil cooler with fan is about all you can do, I think.
This is on a previous bike, but its in the same position on my LRS and King.
I realize you are marketing products, but your engine “damaging” temps are not realistic.
I am not sure we have ever referred to above 270F as damaging temps, but definitely there is accelerated wear occurring, and max potential power is not being generated.
The fact that it is frustrating, or seemingly unrealistic, does not change the facts.
1. Around 270F ET is when an engine (TC or M8) starts putting out less power and accelerated wear is occurring. This is easily demonstrable on a dyno. It also is supported by simple deductive reasoning of the fact that HD starts trying to cool it down at those temps.
2. Take any HD that has had 10k miles or more, where a good percentage of those miles was above 270F, and do a leak down test (which will show if there has been accelerated wear or not) and see what you get.
I'm not sure that HD uses engine temp to derive timing and fueling. As I understand it they use the cylinder head temp. If not then why do they even bother to calculate it?? It seems to me that it makes more sense to use the CHT as it's the number that the chamber walls are calculated to see based one ET and motor load. It's an estimate of what's going on in the combustion chamber which is where you want to determine fuel and timing.I'll agree on TCs that ET and oil temp will be the same at constant load. I've seen it using a thermocouple recording device which is accurate to 1 degree.
While you try to set hard limits on temps, it seems to me that it can be raised if using synthetic oil.. One of the ways I've found that tells me where the motor is running hot is pulling the valve covers and looking at the brownish build up on the insides.. Switching to synthetic reduces or even eliminates any buildup..
- The built-in safety mechanism, installed by Harley in the Delphi ECM, is designed to retard the timing when the ET sensor in the cylinder head hits around 270* F. (the timing retard is actually based off a calculated CHT #, and that algorithm derived # is almost always hit when the ET sensor crosses the 265-270* F threshold) This is there, partially, as a strategy by Harley to prevent the engine from getting too hot for its’ own good (read engine longevity/warranty claims). Retarding the timing will help prevent the heat from climbing higher, but it also drastically reduces power/performance.
Regarding oil temps and synthetic, 230F is what HD says is normal operating temp for the oil, and it is followed by virtually all engine manufacturers, that 230F is the top temp they want to see, regardless of the type of oil...although most are now recommending synthetic.
My '09 Nightster has a PV w/Target Tune., DK 636V intake, V&H SideShots exhaust and an external breather setup. The tune is from FM and it's a fair bit fatter than the original stock tune. Essentially, it's a stage 1. My experience, the Nightster can run anywhere between the 370s to the low 400s. Commonly, it will be in the low to mid 380s. When I get into slow speed situations - following slow traffic up hills in the mountains for example - it can creep up to the 390s to low 400s. The only way I might see the Nightster stay consistently under 375 (max mentioned in the video), is while riding in the winter.
My '18 Heritage 114 is pretty much stock. It has the American Custom Exhaust mufflers (no CATs), a HD K&N filter, and a tune from FM that's fattened it up a tad. I don't have fangs on it. The Heritage ETs typically range in the 270s to low 300s (below 310). On a warm summer day, I will commonly see ETs in the low to mid 280s. The temp can creep up to the 290s or higher depending on what I'm doing (similar to the Nightster). Cruising 80 on the interstate on a hot day, the ETs might creep up into the low 300s. No matter what the ridding condition is, my oil temps (measured via oil temp gauge dip stick) always run between 200 and 210. I can't recall ever seeing the oil temps as high as 230. Similar to the Nightster, the only way I might see the Heritage consistently run at or below the target ET of 260 is while riding during winter.
Are the stated temperature targets realistic? Meh? All I know is that I've never been able to hit those targets.
My 2 cents.
Sporty ET is just a hair high, but that could be margin of error on calibration on the sensor.
M8 is close too, but probably outside the margin of error on the sensor. I would try and get it down if it were my bike.
Here is just one of our Customers that has gotten his temps down on his M8. We never went over 270F in Arizona, with some hard riding. Also, side not on another misunderstood subject of MPG is addressed in this video, starting around the 6:05 mark. The discussion of temps starts around the 9:08 mark.
One would have to run full or accelerated life engine tests to determine just how much longer. I think what many members are saying is air cooled without fans is good enough and long enough for motorcycle application. All good. My input is it can be improved with fans - not that fans are required or necessary. That is all.
DKCustomProducts.com
Ambient temp: 50F
Cruise set to 75mph
6th gear
3000 RPM
MAP: 58 kPa
Engine temp: 307F
Head temp: 343F
These temps are reached 5 miles down the road immediately after a cold start.
Temps are constant for the remainder of the 30 minute ride at 75mph.
Ambient temp: 50F
Cruise set to 75mph
6th gear
3000 RPM
MAP: 58 kPa
Engine temp: 307F
Head temp: 343F
Ambient temp: 50F
Cruise set to 75mph
6th gear
3000 RPM
MAP: 58 kPa
Engine temp: 307F
Head temp: 343F
I have not hooked mine back up since I added the fan to my oil cooler, or the Wards fans I installed last year. I just feel better!
I need to check and see if there is a difference. I will do it this year after the rebuild, and dyno tune.
Ambient temp: 50F
Cruise set to 75mph
6th gear
3000 RPM
MAP: 58 kPa
Engine temp: 307F
Head temp: 343F
