1982 FXR Restoration Thread
mike at 47 industries manville NJ and you can mail it to him - can and will fix it tell him your one of my guys
Yes, Mike did a great job on my transmission case, you can't see where it was repaired. But shipping back and forth would be a killer. I'm sure there is someone around here that can do the welding and I'll take care of the cosmetics. Thanks though
Then today was 70 degrees with low humidity. Perfect paint weather. I made stands for the tank and fenders with parts from a friend's tent, and some wood covered with boat trailer bunk cloth.
Gave the parts a quick once over with 320 grit paper and then spent an hour or so cleaning them with acetone. I also saw on the right side of the tank where the original tank decals discolored the metal! Now I have true measurements.
A little masking tape and they are ready, along with the side covers:
I'm using PPG Omni Epoxy Primer, and the supply house told me three times it goes on before body filler, so that's what I did:
I'll give them a few days to cure then do body filler, sandable primer, and another coat of epoxy primer before paint. I'm looking forward to making progress.
New Old Stock Showa Fork Assemblies
Two inch longer fork tubes part number 45644-77 are used on 82-up FXRs as well as 77-82 FXS and Sturgis models, so perfect for me.
Evercoat is the gold standard for body fillers. I used their Rage because Ultra was too expensive, and I am not a production shop.
First scuff the areas lightly with 80 grit and green scuff pad in the holes. Then mix a ribbon of hardener with a 4″ puddle of filler. Nice of them to use a 4″ diameter can that I can use as a gage.
Two layers of filler got the tank almost perfect. Use 80 grit to get the filler close, then contour with 120 and then finally with 220 grit to smooth and feather the edges. The key to a good contour is close your eyes and feel the surface. Your fingers will tell you if it's right. I had something to do this evening so I’ll finish tomorrow.
Rear fender had a few wobbly places. I hammer and dolly’d them close, and they came out good with filler. The rear seat bolt hole needed the most work. There is a screw on the inside to protect the hole. I’ll clean that up when it’s ready for primer.
Since body filler absorbs water, I’m storing the parts inside.
The next few days will have low humidity, so I’m looking forward to more progress.
Then I sanded all the parts with 220 grit and looked around for shiny spots.
I mixed up a couple batches of glazing putty. It uses half the amount of hardener, but still kicked quicker than the filler. Wasted a bunch, but got all the parts finished. This goes on very thin, and is for pinholes, etc.
Then it was time for three coats of Omni 2K High Build Primer Surfacer 15 minutes apart.
I'll let them cure for a while then do the finish sanding.
