Conversion
Old Apr 2, 2021 | 12:58 PM
  #51
johnjzjz's Avatar
johnjzjz
I hate typing in the future if you already know what you want dont ask about something else
Old Apr 2, 2021 | 02:24 PM
  #52
rickss69's Avatar
rickss69
That's fine John...I had already made it clear what I wanted in post #39...it has never been about something else. If you hate typing that much it is an easy thing to just not reply.
Old Apr 2, 2021 | 03:16 PM
  #53
johnjzjz's Avatar
johnjzjz
I like that idea - done
Old Apr 2, 2021 | 03:31 PM
  #54
rickss69's Avatar
rickss69
There you go...typing again.
Old Apr 6, 2021 | 05:22 AM
  #55
rickss69's Avatar
rickss69
Turned out the ignition switch was indeed the reason for the headlight/taillight not working. It had a 6-pole switch, but I replaced it with a 5-pole which I believe was on it originally. The generator dash light remains lit when running and a meter shows it is not charging at the battery location. Can I check for output directly at the generator studs to eliminate possible wiring problems in between? I did pull the regulator cover off and it looks like new with no corrosion.
Old Apr 6, 2021 | 09:01 PM
  #56
rickss69's Avatar
rickss69
Changed out the sticking petcock today and found a good amount of rust/sludge in the tanks. I'll be pulling those off soon to clean and seal...may lead to a complete paint redo before its over.
Has anyone ever seen or know about maybe adapting a horse saddle for a seat on a Electra Glide? Just thinking...sans the stirrups of course lol!
Old Apr 7, 2021 | 11:15 AM
  #57
rickss69's Avatar
rickss69
Just as I suspected...tank emblems siliconed in place. I'll get the proper brackets tacked in position before sealing and paint.
Old Apr 7, 2021 | 02:23 PM
  #58
rickss69's Avatar
rickss69
Guess I'm committed...all the tins off.
Old Apr 8, 2021 | 09:04 AM
  #59
tld6008's Avatar
tld6008
That was a pretty nice looking bike, definitely need to fix the seat
Old Apr 8, 2021 | 01:27 PM
  #60
rickss69's Avatar
rickss69
Cut a Tracker bar in half last night and swapped them from the buckhorns...thinking I will like these much better. About 32" in width.
