Primary noise
Old Jul 23, 2021 | 08:55 PM
77shovel77's Avatar
77shovel77
Stage III
Default Primary noise
Hey guys I recently changed out the battery on my 77 Shovelhead, but now I’m hearing what sounds like a spray paint can when you shake it. I reached out to the guy who built it and even sent him a video but I’m still skeptical of this noise I’m hearing. I don’t know if I’m psyching myself out but I usually would t overlook a noise that sounds unfamiliar. I started the bike up and it seemed to ride fine but it definitely sounds like something rattling around in there.
Old Jul 23, 2021 | 09:34 PM
1981 suprglide's Avatar
1981 suprglide
sound like a push rod
Old Jul 23, 2021 | 10:21 PM
fergerburger's Avatar
fergerburger
more info please - why do you think it is the primary?
Old Jul 23, 2021 | 10:35 PM
1981 suprglide
you're right if its coming from the primary what kind of chain tensioner you're using? if it's a york that's normal
Old Jul 24, 2021 | 01:46 AM
77shovel77's Avatar
77shovel77
Stage III
Because the noise I’m hearing is coming from that area, today when I rode it though I noticed that coming out of first I heard what sounded like a scraping noise and could feel it as well. I’m thinking it might be the inner primary bearing? As for what cable tensioner I’m using I’m not sure because I haven’t dived into that part of the bike since I purchased it.
Old Jul 24, 2021 | 01:47 AM
77shovel77's Avatar
77shovel77
Stage III
Hopefully the video uploads
Old Jul 24, 2021 | 02:06 AM
fergerburger
no video up yet but open the primary inspection cover and check your chain - does the noise change when you pull the clutch lever? does it change with RPM?
Old Jul 24, 2021 | 02:38 AM
john lee's Avatar
john lee
determine wether is belt or chain primary if its belt its probably clutch noise when engaged. id still take the primary off and check inside for anything abnormal
Old Jul 24, 2021 | 07:56 AM
johnjzjz's Avatar
johnjzjz
The chain is too tight - you can only adjust it on the tight spot of you adjust it on the loose spot its making a snapping sound
Abandoned
Aug 18, 2013 02:57 PM
Falcon195
Aug 2, 2013 04:11 PM
seeds
Aug 10, 2011 06:47 PM
OLD 96
Feb 14, 2011 10:38 AM
rjlman
Aug 16, 2008 07:44 PM
