?Harley replace black stick on on/off/acc ignition surround?
My black ignition surround label is fading..I ordered a new label from HD that's coming..
Maybe instructions to remove the old one will be included..idk..
Googling didn't help atall..
It's down tight..
Someone know the best way about this?
Thanx
I just replaced mine. Lemme see if I can find where.....
Can't find where I got mine, but here's a part # from Kutter H-D:71302-93A $2.55
My research indiactes they have one, but I could be wrong.
I used a heat gun set on low to remove the old one. Came off in less than a minute. Cleaned the residue with acetone (carefully) then Windex. Use care when applying the new one: once it's down, it's down.
My receipt is somewhere..don't know exactly where right now..
Probly the usual ways to remove decals is the same for this..
I think all I have round the house is alcohol..idk
It's down tight..
Thanx
heat up the area with a hair dryer or heat gun .....this will soften the adhesive ....use a sharp small screw driver or box cutter to slowly lift the edge of the label insert.....slowly pry up the old label and it will come off fairly easy . clean the area with a brake cleaner soaked rag .... let dry....apply new label .
