Front rotor hitting caliper
Old Jan 25, 2021 | 07:13 AM
ThePaintPirate's Avatar
ThePaintPirate
Originally Posted by bad tappets
Is it hitting the caliper, or is a pad dragging? Spread the pads/pistons out, see if that helps. Disk side bearing should be installed/seated first, then install spacer and other side bearing.
I'll see if I can take a better picture, but I don't think it's hitting the caliper, but only by the width of a hair. I'm not getting any grinding sounds that would make me believe that, just usual brake pad sound.
Originally Posted by showin4fun
That is a aftermarket wheel?
Did you check the length of the spacer between the bearings to make sure it was letting the bearing seat correctly?
Should there be a seal over the bearings? Does not look like there is enough room there for a seal on either side.
Factory 21" wheel, dealership pressed in the bearings, not sure about a seal.
Originally Posted by Shawry
Looks like the disk side bearing is not seated properly.
I'm starting to think this after looking back at some pictures I took when running the rims to the dealership. The old bearing looks pretty deep compared to the new one.
Old Jan 25, 2021 | 10:08 AM
MCSarge's Avatar
MCSarge
The old bearing does look like it was set deeper than the new one. So you have a choice, either have them reset the bearing depth or just as you suggested earlier shim the caliper over a little. Shimming the caliper isn't a big deal a lot of aftermarket calipers come with a shim kit for just that reason. Personally if the wheel is turning good and true, I would rather take out 2 easy to remove bolts and shim the caliper than mess with the front wheel and possibly have another problem arise. Just my my .02. Good luck on your project.
Old Jan 25, 2021 | 10:29 AM
CoolBreeze3646's Avatar
CoolBreeze3646
How much play in in the center spacer between the bearings? Should be an interference type fit with it just barley able to move with the bearings against it. If it is loose then the bearings were incorrectly installed. Maybe the incorrect bearings where pressed in?
TexNorth's Avatar
TexNorth
I have a dumb question. Is there a washer/shield over the seal on the new bearing? It looks like a shielded bearing, not a sealed bearing.
Just checking because I am only familiar with the old fashioned taper bearings.
Old Jan 25, 2021 | 10:31 AM
ThePaintPirate
You and I are on the same page, it's just the caliper that's not lining up right so a washer on each bolt seems like an easy fix rather than calling out the tech. It also could be a wider bearing maybe? The wheel spins like silky butter on a hot day, just when the caliper gets involved is when things start to bind.
Old Jan 25, 2021 | 10:33 AM
ThePaintPirate
Not sure since the dealership did the work, could be wider bearings than original?
Old Jan 25, 2021 | 10:35 AM
ThePaintPirate
It does seem to be a different type of bearing than the one that came off. I'm not familiar with bearing types but the old one seemed to have a rubber/plastic black middle section and this new one is all metal.
Old Jan 25, 2021 | 10:45 AM
TexNorth's Avatar
TexNorth
I think that is a shielded bearing, not that it makes the fit any different (but it can, in the width) but you will be replacing it quickly as it is not weather proof. The shield just protects it from fingers but water (read road film) can get in. You really need to go with a sealed bearing (the ones with the rubber in the middle).
Old Jan 25, 2021 | 10:51 AM
gerald martin's Avatar
gerald martin
could be the wrong bearing. does the bike have abs or is it non abs. there are two types of bearings
Old Jan 25, 2021 | 12:54 PM
ThePaintPirate
Interesting read on this thread about how the metal has superseded the old plastic/rubber ones.
https://www.hdforums.com/forum/sport...ng-change.html
