Im new to the softail heritage having ridden and maintained a Road Glide for over ten years. I changed all my fluids this week and the tranny was a challenge since the drain plug is hidden between the rear shocks. The plug came out ok using a deep socket and extension but when I tried to reinstall it, it was a brutal lengthy experience as it kept trying to go in crooked. I finally got about 1/4turn on it and it is stuck. Im sure I stripped out a thread or two. Will a tap clean this up? Is there a secret to putting the plug back in (for future reference?). Will I have to drop the shocks to get access to the drain to retap the threads or does someone out there have a tip?
You don’t say what year bike. My ‘06 tranny plug has both a hex head and Allen wrench. I use the Allen wrench, fits better than a socket between the shocks. Pull your plug, drain oil, clean up the hole and observe what the threads look like (mirror or camera). If the plug is only in there a 1/4 turn, you should be able to clean up any damage with a thread chaser or tap. Go slow use some thick grease on the tap, the grease will help hold any shavings on the tap.
I agree with BadTappets about just trying to clean up the first couple of threads with a greased tap. You can also hold a shop vac next to the hole when doing it to help "evacuate" any particles. I had a dealership strip mine when it was new on the first "free with purchase" oil change. I made them change out the transmission case under warranty. The trick is to get the bike up high enough on a jack to see what you're doing. Otherwise it's a mirror and flashlight trick.
You dont say what year bike. My 06 tranny plug has both a hex head and Allen wrench. I use the Allen wrench, fits better than a socket between the shocks. Pull your plug, drain oil, clean up the hole and observe what the threads look like (mirror or camera). If the plug is only in there a 1/4 turn, you should be able to clean up any damage with a thread chaser or tap. Go slow use some thick grease on the tap, the grease will help hold any shavings on the tap.
I do not own a tap and die set, so I took it to my mechanic and asked him to clean out the first few threads and I am embarrassed to say it cost me more than a good tap and die set so my next question is do you have a recommendation for a good set? Is a 70 piece set large enough or do I need a larger set. I am just an amateur driveway mechanic but I came back to Harley from BMW because I like wrenching and polishing almost as much as riding (been doing all three for 50+ years.)
A 30 piece would probably do most anything youd routinely run across. You can always buy a tap for a size you dont have in a set. Just make sure you get a good quality set. Id go less pieces, higher quality. Vermont American are a pretty good value.
Sometimes it is worth the cost to have someone who knows what they are doing and has done it before to make repairs of this type. You can get into trouble with taps and dies if you have not used them before. Break a tap off in the hole you are trying to fix and you have real troubles. Or cross thread a tap in the hole you are trying to fix and strip out all of the treads.
That said you will most likely need a SAE tap & die set and a metric tap & die set to cover all the types of threads on modern day vehicles as they use both.
First time I changed my tranny fluid I had a hard time getting the plug to go in smooth. I took it and cleaned the plug with a wire brush and wd40! I used the allen key to get it started and it went in nice and easy., I do this now every time I change out my fluid..... swifty
I have a thread chaser set... they are kind of like tap & dies, but not as aggressive. They are sized to clean out threads... not cut new ones... I have an old Craftsman kit, but it looks just like this one... I've seen this kit under various names...
Every time I remove a bolt on my Harley, I take the time to chase every bolt and every thread before reassembly... It works especially well with bolts/threads that use lock-tite....
