Compensator Question
Old Jan 15, 2023 | 01:58 PM
golfblues's Avatar
golfblues
Originally Posted by KiwiKid
I have an '09 Fatboy and used a dremel to ever so carefully shave the part of the inner primary where it was catching. It did the trick. Ensure you give it a good clean before reassembly because it will leave shavings behind.
I did the same with a Dremel and it was easy peasy.
Old Jan 15, 2023 | 08:33 PM
Goldstar225's Avatar
Goldstar225
Originally Posted by kneesinthebreeze24
Thanks for the info!
Does grinding down that lip effect the thickness of the area of the case that the gasket sits on?
It does thin it but even thinned it becomes the same thickness as the rest of the housing.
Old Jan 16, 2023 | 03:17 PM
kneesinthebreeze24's Avatar
kneesinthebreeze24
OK, cool. I think I'm going to give it a try. I'll post back when I'm done.
Old Jan 16, 2023 | 11:41 PM
niv's Avatar
niv
For 2009 heritage , I would have to un bolt the starter from the inner primary, and to do that the oil tank would have to come out to get at the bolts. I didn't want to get into all of that, if grinding down that lip would do the trick.
the oil tank does not have to come off to remind be the primary. Getting the starter out with the oil tank on is a tight affair, but you don’t even have to: you can just leave the starter sitting on the transmission until you put the inner primary back on.
best, niv
Old Jan 17, 2023 | 11:53 AM
kneesinthebreeze24
best, niv
Niv, from in order to get he inner primary case off, I need to un bolt the starter from the back of the inner primary ( two bolts) the rear bolt is not accessible due to the oil tank. I would have to get the oil tank out of the way to get to that bolt.
Old Jan 17, 2023 | 02:20 PM
hattitude's Avatar
hattitude
I have not worked on your year softail, so it may be different in some way..... But it IS possible to get to those two bolts with a long extension and swivel socket on most softails. You can then just pull the starter back a little, and leave it resting there, while you remove the inner primary cover.... I would disconnect the battery before doing this...
It has been discussed on this forum, several people have done it, and I believe there was even a thread with pictures... If you get curious, you can do a search and probably find one or more of those threads discussing how it CAN be done...
However, I have not read about any complications from grinding the lip of the inner primary instead of removing the inner primary... You should be good to go with your plan...
Old Jan 17, 2023 | 03:22 PM
niv's Avatar
niv
as @hattitude describes so well, you’ll need some long and skinny tools. And I would not have claimed so had I not done it myself…
Old Jan 17, 2023 | 03:42 PM
kneesinthebreeze24
Thanks man, I'll take another look around the forum on removing the inner primary. Maybe I'm missing something . Thanks for the suggestions, I do appreciate your ( and everyone's) help!
ABQ-Jammer
Exhaust System Topics
Oct 11, 2017 12:37 PM
sg2007
Dec 18, 2014 08:56 AM
Memo7070
Nov 21, 2014 08:06 AM
jerryw618
Oct 29, 2012 10:19 AM
MJR
Jun 30, 2012 06:24 PM
