Gas cap questions.........
Old Nov 22, 2005 | 03:15 PM
SoCal Harley's Avatar
SoCal Harley
Default Gas cap questions.........
I am looking into getting some new gas caps. My first question are the caps on my 06 NT vented? second question, the fuel gauge cap, can it come off by unscrewing it? (I haven't tried yet) I don't need the fuel gauge, I just reset my trip meter when I fill up.
Thanks alot.
Old Nov 22, 2005 | 05:24 PM
mutha's Avatar
mutha
Default RE: Gas cap questions.........
they should be vented but it is only one cap the dummy one with the gauge on it can come off but what are you going to do with the wires? kuryakin has a nice set up with an led gauge
Old Nov 22, 2005 | 06:52 PM
MegaHDman's Avatar
MegaHDman
Fuel injected gas caps need to be vented only if the tank isn't.
Old Nov 24, 2005 | 08:40 PM
tripl8's Avatar
tripl8
All Harley gas caps need to be vented....same as any other gas engine.
Old Nov 24, 2005 | 09:07 PM
sidewinder's Avatar
sidewinder
If I am not mistaken my cap is not vented and it is a EFI. There is a vent in the filler stem. No vent in the actual cap. It is up on the side hard to see. I found it when I thought I had a leak while filling tank with a gas can. It apparently has a small hose that goes to the bottom of the frame.
Old Nov 24, 2005 | 09:19 PM
tripl8's Avatar
tripl8
Thats true..but if you take the right cap off and look under it..you,ll see a "pinhole"...thats the vent...unless Harleys changed something again...
Old Nov 25, 2005 | 11:19 PM
SoCal Harley
Ok,
so I need vented omnes on my 06 NT (Fuel injected)?
I also just want to get rid of the dummy one and replace with a custom one. Is there threads on the dummy one? If I cut the wires going to the dummy one ythe gas light will stay on the dash? Don't want that.
Any info would be great!
Old Nov 25, 2005 | 11:31 PM
tripl8's Avatar
tripl8
Dont know..i dont have any dummy gas caps..but i do know, that a fuel system has to be either pressurized or vented to operate correctly ..i dont run EFI on my bikes..
Old Nov 26, 2005 | 12:39 AM
MegaHDman's Avatar
MegaHDman
ORIGINAL: tripl8
Not true at all, depends on if the tank itself is vented or not. You can buy both vented and non vented gas caps for HD bikes.
Old Nov 26, 2005 | 12:57 AM
tripl8's Avatar
tripl8
Show me a vented fuel tank on a Harley...not one with an "overflow".
