DIY Cheap Mods
Old Sep 21, 2010 | 09:29 PM
  #451
bikersurgeon's Avatar
bikersurgeon
2 more pics
Attached Thumbnails DIY Cheap Mods-phone-sept-2010-461.jpg   DIY Cheap Mods-phone-sept-2010-449.jpg
Old Sep 21, 2010 | 11:25 PM
  #452
Tartarus's Avatar
Tartarus
Looks awesome surgeon can't wait to see it mounted.
Old Sep 22, 2010 | 11:56 AM
  #453
harleyfiremedic's Avatar
harleyfiremedic
Thanks for posting the pics, all your mods look great!
Old Sep 22, 2010 | 12:49 PM
  #454
Boriqua's Avatar
Boriqua
Bikesurgeon,
Nice job.
Old Oct 7, 2010 | 01:17 PM
  #455
bikersurgeon
Thanks for the comments, guys...here's a pic of the fender with the lights mounted and painted black (to satisfy my curiosity...before final paint much sanding and edging is necessary). A concern I have: my side mount tag holder has a nice bright running light but the brake light is barely noticeable. I was going to use these eyes as turn signals (still want to) but feel like I need to use them as brake lights...anyone know if I can run both a brake light branch off the wiring harness and blinker branch and put a resistor in the brake light wiring to make these led eyes serve both purposes? ( I know I CAN...would it work? lol)
Old Oct 7, 2010 | 03:03 PM
  #456
franticbilly's Avatar
franticbilly
You should be able to run a dual circuit for run/brake or run/turn/brake functionality. Checkout www.radiantz.com for necessary parts. They should also be available from other sources.
Old Oct 7, 2010 | 03:25 PM
  #457
bikersurgeon
thanks man!
Old Oct 7, 2010 | 10:29 PM
  #458
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Don't bother trying to make those LED's into run/turn/brake lights. They were not designed to operate at two different brightness levels so trying to get them to operate as run anything else isn't going to work very well.
A better plan would be to make them into brake/turns as both functions work independently without the need for two brightness levels.
I tried that with my rear turns and a single brightness LED array and it didn't work out until I used the rewireing instructions to change the HD run/turn/brake module I was using into a brake/turn.
It works much better and friends following tell me that now there is NO doubt when I'm stopping or turning.
Interestingly enough before I did the rewire on the module the turn signals cycled too fast (it needed an equalizer) but after I did it the turn signals cycle at a normal rate.
Old Oct 12, 2010 | 03:13 PM
  #459
DarkTrak's Avatar
DarkTrak
Heres a mod I just finished. Cut my stock V&S Short Shots flush, had a lenght of 2 1/4" maandrel bent pipe bent up with 100* bends and bought two flappers off of ebay. Measure twice, cut once!! A dash of exhaust wrap, and a spritz of high temp paint...And WHAM...Badassitude! I have a video also for anyone who hasnt seen them in action yet! LOL
Part 1 of 2
Attached Thumbnails DIY Cheap Mods-photo1.jpg   DIY Cheap Mods-image2.jpg   DIY Cheap Mods-image3.jpg   DIY Cheap Mods-image4.jpg   DIY Cheap Mods-image5.jpg
Old Oct 12, 2010 | 03:15 PM
  #460
DarkTrak's Avatar
DarkTrak
Part 2 of 2
