DIY Cheap Mods
But I gotta ask, whats the 9 'kill' marks for on the oil tank?
I stripped the lights and panels off the front end, took loose the top triple tree and opened the tubes to the springs. Harley springs are under MUCH more tension than the Triumphs I worked on so long and I wound up with a fender ding as one exploded on me.
Anyway, I cut some 1" PVC spacers to put over the springs and increase the spring rate, holding the front of the bike up higher in the curves. Couldn't get those in, so cut some 5/8" ones and with ALL my strength, managed to get the caps back on. I then put in Maxim 15 weight heavy fork oil ($9) and put it all back together. Went for a neighborhood cruise and was amazed. The bike feels like it's SMALLER somehow, and it's not stiff at all; if anything, it actually rides SMOOTHER! I can't explain it; you'd think it would be harder but it's not. Stock is 12.9 ounces and I put in just over 13 for less brake diving. It worked.
While the trees were loose, I got to the neck bearings and greased them. Harley necks would take a full tube of grease (and it's weight) to get to the bearings, so many of us don't fill them. If you do NOTHING else, change your oil before 10k. Mine was nasty with metal at 14k. The book is wrong.
Hopefully, now I'll stop banging my crash bars.
The hash marks are for each time a person/animal has been injured/killed by my bike. Which reminds me, I ran over someones cat the other day...gotta get the paintbrush out and fix my count.
Those pipes really work with that bike; super bad. Don't you hate rain? I saw a clipon front fender somewhere else that I thot was a good plan. Someone should do a fab here.
What pipes are those baffles for, V&H BR's?
DarkTrak,
I didn't notice your out in the islands.
Snow is the white slippery stuff we on the mainland, and especially up north have to contend with between around November and March.
Its very annoying cause only someone who's a bit suicidal would try to ride something like a Harley in it.
Now go add your new hash mark.
