DIY Cheap Mods
Old Apr 4, 2010 | 11:29 AM
  #361
gforrest2's Avatar
gforrest2
Originally Posted by IAFatBoy96
I wanted to mount my throw-over saddlebags, but did not want pay the money for the mounting kits. I'm really cheap and like to work on my own bike, so I decided to make my own mounts.
Nice work. I've been thinking about doing something like that myself. Thanks for getting me motivated.
Old Apr 7, 2010 | 03:21 AM
  #362
Catfish9450's Avatar
Catfish9450
Are you sure these links are valid ?
I clicked on the link for a fix to the seat bolt (FXSTC)
& got some dude talking about punching holes in his mufflers !!
Old Apr 9, 2010 | 04:49 PM
  #363
ITSBLU's Avatar
ITSBLU
Thanks for the garage door opener idea! i kind of spun off of it a little. you know the trip reset button on the left side of the speedo? i bought a new switch from my local stealer, $14.00, and a universal remote,$ 25.00. drilled the right side of my speedo cluster and mounted the new button soldered it into the universal remote, wrapped that up real good with some foam(no rattle) and stuffed it under the speedo. looks factory. i love it, real proud of that little mod too. thanks guys! will post pics asap.
Old Apr 9, 2010 | 08:42 PM
  #364
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
ITSBLU,
Good job, but where's the pics?
Where did you get the opener? I have been looking to do the same thing.
I already have the switch ready to go. But need another opener to do it with.
The wife would get a bit more than slightly annoyed if I swiped the one we have in her car for my bike.
Old Apr 10, 2010 | 11:15 PM
  #365
ITSBLU's Avatar
ITSBLU
Default new garage door opener mod
took me a while to figure out how to add a pic but i think i finally got it.
picked up the universal remote on sale at sears.its got two clickers and if you decide to use that one, i recommend programming and using the one on the right, or the one that it shows as number 2. reason being, if you're not the greatest at soldering,and i'm not, the one on the right doesn't have anything else around it to accidentally solder. like i did the first three times i tried to solder it.
Old Apr 10, 2010 | 11:22 PM
  #366
ITSBLU,
Thanks for the tip on where to get the remote.
I'll have to check it out ASAP now that its warming up enough to get the bike out of the garage.
The soldering shouldn't be a problem, I have been doing it for so long I can do it in my sleep.
Old Apr 11, 2010 | 02:04 PM
  #367
richmac64's Avatar
richmac64
ITSBLU,
The garage door opener mod. sounds like a great idea. I'd love to do this myself, but I may have a few questions down the road if you don't mind. I've got an extra remote to use but I'm not exactly sure how to solder it. I'll open it and see if I can figure it out.
Old Apr 12, 2010 | 09:20 PM
  #368
gforrest2's Avatar
gforrest2
Originally Posted by Citoriplus
The wife would get a bit more than slightly annoyed if I swiped the one (garage door opener) we have in her car for my bike.
What!!!! You still let her park in the garage???
Since getting my second bike, the garage is for my truck and my bikes. Her car is outside....and no, I don't scrape the ice for her. Yea, she's a little annoyed, but c'mon, we need to get our priorities straight.
Old Apr 14, 2010 | 07:09 PM
  #369
rustybearing's Avatar
rustybearing
Default RE: DIY cheap mods
Found one today for turning the headlight off during start. Cost me $15 for the relay and socket. The way this works is the relay turns off the headlight when the start button is pushed and it comes back on after the start button is released.
  1. Tap into Pin 6 of Connector 22. This is the Black/red wire.
  2. Take the "tapped wire" and connect to terminal 86 of relay.
  3. Connect terminal 85 of relay to ground.
  4. Cut wire from Pin 2 of Connector 24. The yellow wire from the headlight.
  5. Connect end of cut wire that goes back to Connector 24, to terminal 38 of the relay.
  6. Connect end of cut wire that goes to headlamp, to terminal 87a of relay.
  7. Nothing should be connected to terminal 87 of the relay.
It won't turn off the hi-beam (or any other light), just the low-beam. I like having at least the low-beam go off for starting.
It is a 5 pin. 87 is where it trips to when it's energized(that happens when the starter button is pushed) and turns off the low-beam. Then when it's not energized anymore(release of starter button) it trips back to 87a and completes the low-beam circuit.
My relay was pretty well marked so I just made sure it had all those #s on it.
I bought my 5 position pre-wired relay and socket at an auto alarm place.
Old Apr 15, 2010 | 02:45 PM
  #370
Mordrapheus's Avatar
Mordrapheus
Like the look and sound of what you did but i am not sure i was able to follow what you did in your description...any chance you can be a bit more explicit??
thanks
Or Citoriplus, if you end up doing it can you take more pics?? and post a how to?
thanks
