DIY Cheap Mods
Old Apr 15, 2010 | 03:45 PM
  #371
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Originally Posted by Mordrapheus
Or Citoriplus, if you end up doing it can you take more pics?? and post a how to?
thanks
If I can find a compatable remote I'll be more than happy to do a step by step w/pics.
I just can't find one that will work with the ancient door opener in my garage.
I think the fool thing was installed by Thomas Edison.
Old Apr 16, 2010 | 12:36 PM
  #372
richmac64's Avatar
richmac64
I sure hope you find one that works because I'd appreciate the help too. This sounds like a great mod., I've already got the switch ordered.
Old Apr 16, 2010 | 01:08 PM
  #373
I understand the principals and that kind of installation isn't real hard to figure out.
The tough part is trying to find someplace to hide the remote or circuit board and how to connect it up.
Most remotes are non powered so hitting the button is really just connecting the battery to the circuitry.
The ones that use a 12V battery and that's good because then all you need to do is short the button opener switch and run a pair of wires to a convienient power source or the battery. Then hitting the button on the dash powers the remote up and sends the signal to open the door.
Any that use voltages lower than about 9V can't be directly hooked to the bikes battery or it will fry either instantly or the first time you try to use it.
They need to have some kind of resistor added to the power line to drop the voltage. Personally I would just use the battery it comes with, hooking the door button up to the dash switch and change that battery when it dies.
Old Apr 17, 2010 | 08:09 AM
  #374
dion140981's Avatar
dion140981
Default Garage door Opener
when i performed his mod on my own bike i used an extra remote that i had that came with the opener. i popped it open and checked for voltage when the button was pressed and door opened, i soldered wires to the two points and spliced them into my hi-beam indicator light. now with a flick of the hi-beam switch the door opens and i didn't spend the money Harley wants for a kit that does the same thing.
Old Apr 17, 2010 | 08:26 AM
  #375
rustybearing's Avatar
rustybearing
Here's a site with mini openers. I used the Genie MAT90 and it works well.
http://www.aclickawayremotes.com/cat...tes/index.html
Old Apr 17, 2010 | 05:08 PM
  #376
Punk09Rocker's Avatar
Punk09Rocker
Originally Posted by Rocker_Dan
cheapest chrome I have added on my bike...just some adhesive automotive chrome stripping on the oil bag...
Hey Dan, have you had any problem with the adhesive on the chrome, seeing as the oil tank can get pretty hot? I really like how that looks...now I'm thinkin about addin it to my black'n'chrome...
Old Apr 20, 2010 | 12:13 AM
  #377
RocketRocker's Avatar
RocketRocker
Punk Rocker- I did this remote thing last year by busting open one of the remotes and silicone all over and sticking it under the voltage regulator almost under the frame. I never had an issue with rain or anything....just an idea
Old Apr 20, 2010 | 09:46 AM
  #378
Quadancer's Avatar
Quadancer
I wonder if you guys could fill one with acrylic, like they do for some electronics.
Old Apr 22, 2010 | 10:59 AM
  #379
scottsgretch's Avatar
scottsgretch
great ideas, thanks.
Old Apr 22, 2010 | 03:26 PM
  #380
Mordrapheus's Avatar
Mordrapheus
mmm thinking about it now, I think I have an extra remote for my garage door somewhere, I an just reuse that.
let me look for it this weekend
