"DYNO" Numbers For SOFTAILS
Old Mar 14, 2009 | 05:40 PM
  #91
Smug's Avatar
Smug
Tiiiim2, those are very impressive #'s for a 103" and killer curves on that dyno sheet. Very nice.
Old Mar 15, 2009 | 08:39 AM
  #92
ifixacs's Avatar
ifixacs
Default dyno numbers
98 Heritage Softail Evo Andrews EV/51 cams,10.5:1 pistons,SE heads,stock cv carb jetted , V & H Longshots SAE 74.25 hp and 85.90 max torque expected numbers to be a little better ,but I think I can get better with different exhaust, might do some porting and re-test, gonna finish mine first tho this is wifes!!
Old Mar 15, 2009 | 08:48 AM
  #93
ifixacs's Avatar
ifixacs
Default 98 Heritage Softail
Andrews EV/51 , 10.5/1 pistons, k & n filter, SE heads, V & H Longshots, Stock CV carb re-jetted, DYNA 2000 ignition SAE 74.25 max HP 85.90 max Torque was expecting better numbers , can probably do better with different exhaust, might port and dyno again after I finish mine-- this is wife's!!
Old Mar 16, 2009 | 01:10 PM
  #94
hpfatboy's Avatar
hpfatboy
2nd that, killer curves. Dont think you could get a better 103" build, love those WOODS CAMS.
Old Mar 19, 2009 | 11:21 PM
  #95
oct1949's Avatar
oct1949
Originally Posted by oct1949
This is my dyno sheets with orig stock #'s, then stage1 tune, and again after Andrews 26h cams added.
1st thunbnail is copy of base run
2nd thumbnail is after Stage1 dyno
3rd Andrews 26h cams installed. 3-18-09.
Hopes this helps :
added cam update and Thumbnails of dyno sheet in post # 88....
Old Mar 21, 2009 | 11:46 AM
  #96
GregH's Avatar
GregH
...... D&D's being too loud with the std baffles then not loud enough with the Qt baffle I choose not to change pipes.
Just curious........ are the D&D's too loud from a legal stand point or just for your own taste? At first, I thought that mine were rather loud as well, but I got used to them. I love the sound of a performance built motor!
I also asked about the quiet baffles and was told that I'd sacrifice some power. Well, I didn't stick this much cash into it to lose power so I went with standard.
To be honest, I did want to stay with the Rush slip-ons because I love the look of two pipes but again, I was told I'd be sacrificing some power.
The bottom line is that I'm a power/performance nut and usually don't sacrifice power or performance for looks. Besides, the D&D's look has grown on me!
Old Mar 23, 2009 | 04:29 PM
  #97
ASILKMAN's Avatar
ASILKMAN
Got my build finished last week....
Old Mar 23, 2009 | 09:02 PM
  #98
oct1949's Avatar
oct1949
Sorry ASILMAN I can't see Ur sheet but Your #'s in your thumbnaisl but they sound like they are good,.
Old Mar 24, 2009 | 01:52 PM
  #99
speedstick's Avatar
speedstick
Default its not how deep you fish, its how you wiggle your worm
2007 flstc,103 ci big bore,260 cams,pc III,V&H BIG SHOTS, 100 hp, 100lbs torque
Old Mar 26, 2009 | 11:49 AM
  #100
oct1949's Avatar
oct1949
Greg: was not a legal issue with noise, never heard fatcats live, looked last summer for Fatcats to hear but couldn't find any. Most riders here have never heard of them. Tuners say they are loud. The Rush 2" aren't quiet, we wear plugs most times now. 60% of reason is wife likes what we have.go figure!!!!
I've heard them on the net but haven't found good sound tracks, they all sound different, I know the net is not the place to get a good sound track so I emailed D&D if they had a better website or anyway I could hear them but never got an answer. Other (?) was with the pipe contact on right hand turns.
I like the looks, best 2-1 in my eyes, from what I've seen I believe they are leaders in performance and would have gained some TQ&HP with the fatcats, I just didn't get them because I had some doubts! Next time I have engine work done I'll look at new pipes then...
