"DYNO" Numbers For SOFTAILS
Old Jan 24, 2012 | 10:35 AM
  #591
oct1949's Avatar
oct1949
Originally Posted by FBFletch
2001 Fat Boy:
95 Cu. In. (Overbored stock cylinders)
Compression 10.2:1
Wood Performance TW-6HG Cams
Stock Heads reworked (Bigger intake and exhaust valves, ported and polished)
45mm Mikuni
Hypercharger Pro-R Air Cleaner
Crane Fireball Hi-4TC Ignition
V&H Big Shot Staggered exhaust
Horsepower: 106 Torque: 108
Take those numbers with a grain of salt. I don't entirely trust that they're good numbers (i.e. don't trust that the guy who worked on my bike gave me truthful numbers). After I get my transmission problems ironed out, I plan to have a new baseline done and I'll post the actual charts.
better hang on real good when U nail it... nice build.
Old Jan 24, 2012 | 10:47 AM
  #592
oct1949's Avatar
oct1949
Originally Posted by micpsteve
Just got back my '09 Heritage Softail from the shop after a Super Tuner and Dyno....80hp and 90 ft/lbs! Also the decel pop is worse...my guy says it has to do with the "power chamber" on my Vance & Hines BSS. He says that where the pipes meet they share some holes that allow sort of recirculation and makes it difficult to tune out the decel pop. Thats what was told to me anyways. Very happy with the #'s not so much with the pop.
2009 Heritage Softail
SE Stage 1 AC
Vance & Hines BSS
SE Super Tuner
Dyno @ 80hp & 90ft/lbs
Hey steve, take a pic of that sheet and put it in here if U can.. We like to see sheets even better than just seeing numbers..
Old Jan 24, 2012 | 11:20 AM
  #593
oct1949's Avatar
oct1949
Originally Posted by thornious
PRE 74.7 HP @ 4700 RPM
91 TQ @ 3270 RPM
09 FLSTF
V&H BR
SE Heavy Breather
SE Race Tuner
POST 93.1 HP @ 5095 RPM
109.1 TQ @ 3657 RPM
09 FLSTF
V&H BR
SE Heavy Breather
SE Race Tuner
103 SE Stage 3 KIT
SE259E Cams
Manual Comp Releases
Good job of showing before and after runs..
I couldn't do it because i had the cams added later at a diff dealership so I couldn't get a sheet that showed both runs.
I need to read more on those cams,, they look really good.
Just read a little on the cams. They sure come on earlier than I would have though with their 47* intake close.
Those babies rock. The jump from 2k to 3.5k is great.
Just wondering are U arms about 2 in longer now since U've put them in with the 103BB...
Old Jan 24, 2012 | 11:36 AM
  #594
oct1949's Avatar
oct1949
Originally Posted by Stoood
I attached it twice, I don't understand . . .
Nice build, and great numbers.
Old Jan 24, 2012 | 11:42 AM
  #595
oct1949's Avatar
oct1949
Originally Posted by 97badfatboy
08 Ultra, 103 build
AH no, U sneaked a touring bike sheet here in the Softail Dyno section......,,,
That is a good, no, a great build...
Old Jan 24, 2012 | 10:24 PM
  #596
txphatboy's Avatar
txphatboy
Originally Posted by TheTroupe
Over 80 ft/#s of torque from 2300 through 5250
Smooth HP curve.
What more could I ask for from an other wise stock 88ci.
Troupe,
Are you using a PC canned map? You mind sharing which map? I have 204's, se intake, and 2-1 big radius, but using a map for 203 cams and V&H BSS. Planning big bore and tune in a couple months and need a map to get by until then. thanks
Old Jan 26, 2012 | 04:03 PM
  #597
Brutus01's Avatar
Brutus01
Hmmmm.....that's strange. I have the same setup as Thornious above except I have D&D 2-1 and RSD A/C and our HP #'s are really close but the TQ numbers are way off. ANy ideas on that?
Old Jan 26, 2012 | 04:43 PM
  #598
SHO_EM's Avatar
SHO_EM
check idea for tracking all these in one place:
https://www.hdforums.com/forum/softa...d-numbing.html
Old Jan 27, 2012 | 05:46 PM
  #599
Sash302's Avatar
Sash302
what kind of cams you have stock?
Old Jan 28, 2012 | 04:16 PM
  #600
Brutus01's Avatar
Brutus01
I have the stage 3 kit which is the 259e cams, 10.5:1 pistons, and the other parts it includes.
