"DYNO" Numbers For SOFTAILS
2005 FLSTFI
88 TCB
SE 211 cams
Flowed heads
V & H 2-2 Big Radius with baffles
240 rear end conversion
PC3
71.24 HP, 79.81 TQ
Now with intercooled Procharger, the rest of the motor is the same.
122.7 HP, 117.53 TQ
The pipes aren't the best for bottom end, but they look & sound good, and I've probably got "sufficient" power anyway.
Same dyno.
Now have 95 cube kit & Wiseco 9:1 forged flat top pistons and ThunderMax ECU. Yet to get dyno run with this combo. I now have problems with wheelspin!
Cheers, Mike
Time slip at Sanair. I'm in the right lane...
He replaced it w/ a '47 he restored in '69, still in its' original black finish. Your X-Bones w/accents of flat black & chrome looks tough AND classy at once. -Is it lowered, or the front end kicked out some? Mine seems to under-steer, and handling feels "mushy", in town. I may try a progressive shock up front. Tracks great on the highway. I notice your Woods 555's have the same lift as my cams, lots less duration. I'd like to see the Dyno. Porting and added duration generally add usable torque in the mid and upper midrange (provided displacement is adequate). While you have very adequate power and torque now for your engine's size, as you go forward with the 107ci bore kit, you'll need more duration and compression to reap the benefit of the added displacement. I have Andrew's 55's, w/ Sachs' best 103" top end, KB flat tops, jugs decked, heads milled & porting, $-Ouch, but I love that torque curve, however, it is too choppy around 2300 for a heavy bike, that's why the torque build on my trike has stock heads. (Addl. lift did help it in the low end when I added it). Back to the subject, the Springer is "one" model I hope Stays; at least until I have them all, and a healthy Dyno chart here for each one as well.
That is One Very Sharp Ride! - Stoood
Ps. I've been thinking, a thread in which we all combined our Dyno numbers for differing configurations of torque Cams would be the next logical step in our "Cam Data-Base", and would also continue to further our understanding of Cam Physics. What do you all say? It'd be great infotmation to have for future builds!
The son did them this summer on his new Streetglide and loves them..
He did 204's in his 07 Deuce and 09 NT and was happy,, but he likes these even better in the new bike.
He did the V&H's 2-1-2 for headers.
thinking he ended up with 80/95 and a really good line from 2-5 k rpms
I'll see if I can get him to post the sheet.
Today had dealer install....
New Screamin Eagle Stage 1, SESPT and Vance/Hines Big Shots Staggered
Before
Max Power = 52.67
Max Torque = 66.45
After
Max Power = 71.43
Max Torque = 82.83
