"DYNO" Numbers For SOFTAILS
Old Sep 19, 2011 | 11:46 AM
  #541
terryrh's Avatar
terryrh
Originally Posted by dongorgon
85.07HP/101.08TQ STOCK CARB JETTED,cam, HEAD WORK, 2in2 v&h & 98" bore peak 3850 rpm.
kind of bike?
Old Sep 22, 2011 | 03:47 AM
  #542
FBFletch's Avatar
FBFletch
2001 Fat Boy:
95 Cu. In. (Overbored stock cylinders)
Compression 10.2:1
Wood Performance TW-6HG Cams
Stock Heads reworked (Bigger intake and exhaust valves, ported and polished)
45mm Mikuni
Hypercharger Pro-R Air Cleaner
Crane Fireball Hi-4TC Ignition
V&H Big Shot Staggered exhaust
Horsepower: 106 Torque: 108
Take those numbers with a grain of salt. I don't entirely trust that they're good numbers (i.e. don't trust that the guy who worked on my bike gave me truthful numbers). After I get my transmission problems ironed out, I plan to have a new baseline done and I'll post the actual charts.
Old Sep 24, 2011 | 06:31 AM
  #543
Weevil's Avatar
Weevil
Even if the numbers are a tee tee lower, still great results. Be interested to see the sheets once it's dyno'd.
Edit; Just remembered you were the guy who had a rough time with Shane Wallace Cycles. Wish you the best of luck.
Old Sep 25, 2011 | 04:16 PM
  #544
dongorgon's Avatar
dongorgon
Originally Posted by terryrh
kind of bike?
2003 fsxt softial wheelie faast. ill scan and post soon
Old Oct 19, 2011 | 08:48 PM
  #545
oct1949's Avatar
oct1949
Originally Posted by hdspringer02
Had it on the dyno this morning. 95 in big bore, SE 204 cams, mild head work, RSD air cleaner, and V&H short shots with BCT baffles. I think it may be time to move to a decent 2-1 pipe. The HP is a little lower than I hoped for. 104 TQ and 84 HP.
That pretty decent #'s and they don't surprise me.
Bout the same as most SE 103 BB kits with the 255's
Old Oct 31, 2011 | 09:13 AM
  #546
Ty-Rod's Avatar
Ty-Rod
6th Gear
I just pick up my FXSTC from getting a 103" Stage 3.5 upgrade done to her and here is my Dyno Jet sheet. Before the work the bike only had a stage 1 AC and Tuner and put out 74 HP and 78 TQ.
2010 FXSTC, 103" Stage 3.5, SE CNC Heads, 259E Cams, 10.5:1 Pistons, Bassani Road Rage 2-1 Long, SE Race Tuner.
I was in the Dyno room the entire time it was being tuned and as the tech was fine tuning the AFR I saw one of the runs put out 108 HP and 117 TQ. This Dyno Sheet was from the last runs he did and it shows 101.73 HP and 111.43 TQ.
I don't think that is too bad. The bike will be putting out 90+ TQ from about 2650 RPM's until about 5750 RPM's. I rode the same day the bike was completed for over 260 miles and was very impressed with the results.
Last edited by Ty-Rod; Oct 31, 2011 at 09:31 AM. Reason: Didn't download the Dyno Sheet.
Old Nov 1, 2011 | 10:47 PM
  #547
dongorgon's Avatar
dongorgon
Head work ,98" bore,9fg woods,ness a/c & vh 2in2 long shots.tq comes on nice and early, hp pulls all the way to 6700rpm as far as the setting on the ign. mod. not sure why tuner cut off @5080rpm.mmmm
9fgcam does great on a little bore
Old Nov 1, 2011 | 11:10 PM
  #548
dongorgon's Avatar
dongorgon
? seems alot of these build make power a well into the 200+rmp range vs before ,mmm say right of idle . any insght will be appreciated . still learning
Old Nov 1, 2011 | 11:17 PM
  #549
dongorgon's Avatar
dongorgon
bike is a 2003 fsxt by the way stock carb and clutch
Old Nov 14, 2011 | 12:00 AM
  #550
oct1949's Avatar
oct1949
Attachment 215052
I don't think U'll reading U dyno right, Ur tuner should have explained it better.
Every dyno sheet I've seen shut down at 6200 rpms at most.
Winding a B motor to 6700 if done is really really asking for trouble. IMO.
That why some tuners set the limiter to 5800 rpm's not 5080 as U've posted.
