"DYNO" Numbers For SOFTAILS
Old Aug 13, 2011 | 06:45 AM
  #531
WAhog's Avatar
WAhog
Default New heads and cams...
110/104. Safe build, very smooth, good TQ and great HP.
Old Aug 13, 2011 | 12:21 PM
  #532
05FATfatty's Avatar
05FATfatty
Originally Posted by Saphira
2010 Softail Convertible SE
92 HP and 113 TQ
SE what? Air cleaner, slipons? Cams? The 92 HP seems good, but the 113 ft/lb torque seems a bit over the top (or are we talking n/m torque). A bit more info on what the bike actually is would be good-a dyno sheet would be good too.
Cheers, Mike
Old Aug 13, 2011 | 12:32 PM
  #533
terryrh's Avatar
terryrh
Cheers, Mike
It's the SE Softail Convertible with the 110 in it
Old Aug 14, 2011 | 04:17 AM
  #534
05FATfatty's Avatar
05FATfatty
Oops. My bad. In that case, I would have expected more power. I'm guessing the motor & ancilliaries are stock, so improvements are not far off.
Cheers, Mike
Old Aug 14, 2011 | 09:54 AM
  #535
terryrh's Avatar
terryrh
It seems quite on par for a stock 110 set-up. Remember Harley detunes the s*** out of their bikes. Don't kno wwhat kind of tune he's got on there but that seems just a little over stock
Old Aug 15, 2011 | 09:48 AM
  #536
oct1949's Avatar
oct1949
92 HP and 113 TQ
The stock CVO 110 doesn't put out 113/92,
I just checked Fuel Motos upgrades for them.
They dynoed the stock CVO 110 at 96.5TQ and 83.8 HP.
After adding their up grades they got 114TQ /95HP..
Old Aug 15, 2011 | 09:53 AM
  #537
terryrh's Avatar
terryrh
Thanks I stand corrected. I thought it was higher than that.
Old Aug 17, 2011 | 05:15 PM
  #538
oct1949's Avatar
oct1949
Originally Posted by hdspringer02
Had it on the dyno this morning. 95 in big bore, SE 204 cams, mild head work, RSD air cleaner, and V&H short shots with BCT baffles. I think it may be time to move to a decent 2-1 pipe. The HP is a little lower than I hoped for. 104 TQ and 84 HP.
The head work does help..
I've seen a bunch of 103's dyno's and they are right where U are now..
105/85...
Without seeing Ur dyno I can't really say too much, But most 2-1's will move the TQ to the left quite a bit and last longer in the low-mid range over the Short Shots that don't usually come on strong till after 3000-3500 rpms.... BUT overall they usually dont give U any better numbers.
Dont play the numbers game,, play put the power where U need it game.
Old Aug 29, 2011 | 04:03 AM
  #539
Brutus01's Avatar
Brutus01
Anyone ever used Rod's Performance in north Alabama for tuning and head work?
Old Sep 18, 2011 | 10:47 PM
  #540
dongorgon's Avatar
dongorgon
85.07HP/101.08TQ STOCK CARB JETTED,cam, HEAD WORK, 2in2 v&h & 98" bore peak 3850 rpm.
