96 CI
Stage 1
SE air cleaner
V&H Bigshot slants
PC III
base line 73.36 HP -- 82.24 TQ
After
76.98 HP --- 86.14 TQ
Done by Horespower inc. Erie,Pa
Decell pop is gone and it pulls a lot harder in every gear.
6th gear is way better!
I had them redo the throttle body with the bore and polish.
I doubt that contributed to the numbers much since the engine is bone stock. it will be there when I need it for the stage 3 100 HP/TQ kit they offer.
these are the guys that make the throttle bodies a lot of folks use when they build. I figure since i'm only about 45 minutes away I cant go wrong.
Reason: forgot something
03 FLSTFI, 95", Screamin' Eagle 10.5:1 high compression cast pistons milled to 8 cc's dome volume, 9.4:1 static compression, Stage II CNC ported heads, 1.725" Screamin Eagle Pro Rocker Arms, Andrews 21G Cams, Stage 1 K&N Air Cleaner, D&D Fatcat w/louvered (quiet) baffle, Dyno Jet Power Commander III USB.
So, the difference between STD & SAE smoothing is 2 to 2 1/2%? Pays to check what smoothing has been used-as has been mentioned earlier, when you're boasting at the bar!
Cheers, Mike
What exactly is "smoothing" and what is the difference between std and sae? Maybe a dumb question but just curios. My dyno sheet says CF:SAE Smoothing:5
"A detail that the dyno operator has complete control over is the "smoothing" factor. This allows the operator to show more or less detail in the lines on the graph. Our Dynojet 250i has a smoothing scale from 0 to 5, with 0 showing the most detail. More detail generally produces higher output as the lines on the graph will show small spikes. If the bike is tuned well, there will be a smaller difference between 0 and 5 smoothing. See the first 3 and last 2 rows in the above chart to compare the results of different smoothing factors."
Smoothing plays little into the numbers on the dyno graph, whether it be a Standard (STD) or Society of Automotive Engineers (SAE) readout. The difference is the correction factors used in STD and SAE.
2006 flstfse2 autumn haze
124 r&r motor w/billet round port heads w/comp release
horsepower inc. 58mm throttlebody
speed's high velocity air cleaner
static compression ratio 10.8:1
s&s crankshaft
camshaft s&s 640
s&s roller rocker arms
sert
rivera pro clutch
8mm hypo wires
r&b racing lsr 2-1 pro stock 124 2" primaries c style 17" collector
brembo 4 pad calipers front and rear w/12.6" front rotor, 11.5" rear
baker builders kit.
Since engines perform differently in differn't atmospheric conditions, they developed correction factors. SAE and STD are the most common. SAE corrects your dyno run to 29.23 InHg (99 kPa) of dry air and 77 F (25 C). Si if your bike gets run and it's 86 degrees and pressure is at 32 InHg the program will adjust the numbers to 22.23" Hg and 77 F. This is for comparison. STD corrects to 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5 C). STD generally produces about 4 percent higher numbers than SAE that's why alot of shops print the sheets in STD. But in reality, SAE is the more accepted (common) correction in the US. There is also an UNCORRECTED factor that shows your actual HP and TRQ numbers for the condition the bike was run in on that particular day. But it's not really good for comparison value since youd have to run bikes in identical conditions for a comparison.
It's just a little 80" evo i built in 1998, but she runs pretty good.
Branch #4 heads, 10.8 comp.SE adj. ign. SE-57 cam, 42mm Mikini,SE big bore intake
2 1/4 x 30" pipes. Rebuilding now for the magic 100+ hp mark.
Dyno Tunes in Burlington (Walkers Line and Harvester Road). Guys name is Bruce Roy. Took my 2005 Springer there on Friday; amazing work. Found 12hp in tuning, throttle and crisp, idles finally.... amazing work and worth every penny.
