"DYNO" Numbers For SOFTAILS
Old Jun 7, 2012 | 02:17 PM
  #691
refg3880's Avatar
refg3880
Originally Posted by harleytuner
Stock cylinders that have been bored out to fit the aftermarket pistons. He's saying that he didn't just buy a 95" kit out of a catolog that came with pistons and jugs.
correct my heads are stock ones ported by hillside, they have no "markings" on them, looks bone stock.
not like these how they say S&S on them
Old Jun 7, 2012 | 08:42 PM
  #692
TheTroupe's Avatar
TheTroupe
Thank you
Old Jun 16, 2012 | 08:55 AM
  #693
NVS's Avatar
NVS
2003flstci
stage 3 tman heads
tr625 cam
98 inch
thunderheader
112.73 Hp 110.68 Tq sae corrected will post sheet if I can figure out how.
Old Jun 16, 2012 | 02:44 PM
  #694
jessultra's Avatar
jessultra
wow nvs those are nice numbers
Old Jun 18, 2012 | 12:05 PM
  #695
Road_Clam's Avatar
Road_Clam
Got my advanced tune from Rob's Dyno service, and while I didn't gain huge hp and tq, (+5 hp and +4 ft/lb respectively) I did gain some very crisp throttle response and fuel economy. My throttle response no matter what engine load or throttle position is instantanious, where before it was good but I had low speed drivability chugging and a flat spot every time I decellerated, then got back into the gas. Rob fixed quit a few ill running issues, including my throttle position sensor baseline that somehow got out of sync. I did my first milage run, and relaxed normal combined backroad milage ended up at 53.8 mpg, I was amazed (I was getting about 41 mph prior). I thought my trip milage was wrong, but my buddy verified he has almost the same miles traveled. So my final advanced tuned dyno pull was 96 hp, and 103 ft/lb torque . Very happy, now my bike really hits hard around 4k, and has a nice wide torque curve, so shifting at anywhere from 4-5K it's making awesome power, and it's TORQUE that's the KEY to a fun street engine
My detailed mod list :
97" flat top piston big bore kit 9.8:1 CR
Revolution Cycles street velocity ported heads
Andrews 54G gear cam conversion
Rivera Taper-lite pushrods
PC III
SE injectors
SE hi flow filter kit
V&H 2" Straight Shot HS exhaust
Big City Thunder monster baffles
Here's my pulls with an off the shelf generic PC 95" map. You can see my afr is like giant waves (not good) :
Here's my pulls with a different map than above both before and after Robs fine tuning. Now the a/f curve more closely follows the ideal 13:1 target a/f after the tuning. Rob individually tunes each cylinder, and tunes each cylinder at 10 different throttle positions. So my engine spent a LOT of time bouncing off the rev limit at 6200 rpm !
Old Jun 18, 2012 | 09:05 PM
  #696
Nunner's Avatar
Nunner
2008 Softail Deluxe (96)
Rush Slip on's
Air is done
PC V
HP 74 / TQ 86
Old Jun 23, 2012 | 10:19 AM
  #697
NVS's Avatar
NVS
Default dyno before and after
this is my dyno sheet 98 inch stage III flstci
Old Jun 23, 2012 | 04:02 PM
  #698
harleytuner's Avatar
harleytuner
'09 Fatboy
103"
SE 251 cams
Roeder Racing heads
Tuned by me
Fatcat TTS mastertuner
Old Jul 18, 2012 | 04:46 PM
  #699
professorzoogy's Avatar
professorzoogy
2007 train.....K&N , Vance&Hines big shots and PCIII
Attached Thumbnails "DYNO" Numbers For SOFTAILS-img001.jpg   "DYNO" Numbers For SOFTAILS-sam_0702.jpg
Old Aug 2, 2012 | 10:42 AM
  #700
oct1949's Avatar
oct1949
Prof Zoo what cams are U running.? Or did u just do head work.?
90#'s - 93#'s of TQ from 2k to 4500rpms is what a lot of others would like to get.
I've not seen any 96'er with ST1 and not have cams do that yet in a Softail.
