"DYNO" Numbers For SOFTAILS
Old May 21, 2012 | 06:20 PM
  #671
oct1949's Avatar
oct1949
Originally Posted by TheTroupe
Some people have asked me to re-post this. So here it is.
My goal was a broad and smooth power curve. Lots of low end torque and reasonable sound.
Starting Point: 2003 88ci. FLSTCi.
The Changes: SE Air intake with K&N Filter, Power Commander III tuned by the dealer, SuperTrapp 2:1 with 23 discs. SE 204 cam, with upgraded cam plate and SE oil pump.
Not Changed: No head work, stock push rods, stock lifters, stock valves, stock bore & stroke.
The Results:
Max torque 88 @ 2700
Max HP 81 @ 5450
That's a great line for the 204's... My Son have the 204's in his 07 Duece and 09 NT and didnt come close to what U got under 3K and He even had the Advance 4* gear install to move the line Left and they didn't come on the cam till close to3k rpms
I've never seen them come on that early, Usually then peak around 3500 to 4K rpms, not peak under 2500...
Those pipes must be really making a Diff..
Old May 22, 2012 | 09:49 PM
  #672
Junker's Avatar
Junker
What are average numbers for a stock 2012 103 ? I have V&H bss , stage one air filter and sert. What is an average number for this combo? I have a fat boy if it makes a difference from model to model.
Old May 23, 2012 | 12:36 AM
  #673
bvkamp's Avatar
bvkamp
Default 2011 Blackline
103 ci, V&H Big Shot Staggered, SE Air Cleaner, SE 255 Cams:
89.46 HP, 102.61 ft-lbs
Old May 25, 2012 | 01:28 PM
  #674
DrkHrse's Avatar
DrkHrse
6th Gear
06 Train, stone stock TC88 with Hooker Troublemakers and SE heavy breather. 78.89hp 78.42tq. Forum wouldn't let me upload the dyno sheet unless someone can tell me how to shrink a PDF
Old May 25, 2012 | 03:13 PM
  #675
terryrh's Avatar
terryrh
There should be a compress option in the menu
Old May 25, 2012 | 08:06 PM
  #676
TheTroupe's Avatar
TheTroupe
That would be about right if you have re-jeted the carb or tuned the EFI.
Old May 25, 2012 | 09:53 PM
  #677
DrkHrse's Avatar
DrkHrse
6th Gear
Forgot about that. It has a Power commander V with one of Fuel Moto's canned maps. I havnt had it tuned.
Old May 27, 2012 | 11:53 PM
  #678
bullet proof's Avatar
bullet proof
2004 heritage tc88
95" big bore kit
k&n af
se cams
se heads
power commander III
samson mini cholos 2 1/4" dual headers no baffles
max power 85.23 sae
max torque 89.64 sae
do these numbers sound right? owner before me said he dynod it @ 92hp. I added the cholos and dyno tuned it and got 85.23....before tune baseline with just adding the cholos and headers and the af was way off... 77.75 torque 83.81...run conditions 101.44 degrees F humidity 30% 28.59hg at time of dyno
Old May 28, 2012 | 09:32 PM
  #679
KumaRide's Avatar
KumaRide
Originally Posted by bullet proof
2004 heritage tc88
95" big bore kit
k&n af
se cams
se heads
power commander III
max power 85.23 sae
What se cams? Sounds a little light imo for se heads and se cams and 95". Any idea what compression is? Install baffles and gain a couple tq. A 2n1 and tune should get you closer to mid 90's.
Old May 29, 2012 | 08:46 AM
  #680
franticbilly's Avatar
franticbilly
It definitely sounds low.
My 01 Deuce is running:
95"
10.5:1 Wiseco pistons
Underground Performance Heads
Wood TW408G Cams
TwinTec ignition
Stock CV carb (rejetted)
Thunderheader
Big Sucker II
HP 100.1/ TQ 105.7
Once I get the carb bored out or get a Wood King Carb, It'll be on the dyno again. I'm expecting it to come in around the 110HP/115TQ range.
