"DYNO" Numbers For SOFTAILS
Old Apr 27, 2012 | 09:34 PM
  #661
oct1949's Avatar
oct1949
Originally Posted by dbritsch
VEHlaon48
Your post got me thinking so I called the service guy. The dyno run that I thought was stock was actually a pre-SERT tune baseline. Soooo, I find out that the dude ran the dyno with Cam, pipes, and air filter. Then he tuned it with the SERT and got the second numbers. Bottom line is I don't know what it had stock. Now I guess it does not matter, because my numbers are 85/105 and I will go from there!
Thanks
That's normally the way things is done, UNLESS U agree to pay extra for a base line run.. Think they will have to set up Ur bike on the dyno, warn her up and then make usually 3 runs to get a good average reading, then take it off the dyno , let her cool before then can start to do the mods U want.
Thats at least 1/2 to 1 hr added labor plus dyno time that most won't pay for.
Go back to when I started this thread, I posted my base run results were after stg1 was installed but before it was tuned..
So with factory setting and the Rush pipes which are claimed to add up to 5HP more, Still my base dyno was ---63 HP / 78.8 TQ..
So its possible the actual base could have easily been around 60 HP and 76-77 TQ.
Old Apr 28, 2012 | 04:59 AM
  #662
harleytuner's Avatar
harleytuner
Our shop does a comparison (as received) run on every bike we get in that is getting performance mods. It makes it really nice to shop the customer what they gained.
Old May 1, 2012 | 11:30 PM
  #663
OkieNiteTrain's Avatar
OkieNiteTrain
Sometimes on my dyno it's embarrassing to show the customer how much he paid for each HP he gained!! Most of the time it's not worth it. JMO.
Old May 2, 2012 | 05:58 AM
  #664
harleytuner
That's when you need to explain that there is more to a dyno tune than the printout, tell them that although they didn't gain much on wide open but they gained alot on the cruising ranges. That's the problem with dyno runs, people get to caught up in the peak numbers and don't pay attention to the rideability. I tuned a 103 in a street glide last week, all it has is pipes and a/c, the guy thought it would make over 100 HP and 100 TRQ, when he came to pick it up I had him ride it before I gave him his sheet, he came back grinning from ear to ear happy as a pig in mud. Then I gave him his sheet, it was like 90 HP and 103 TRQ (something like that), now he thinks his bike is a turd.
Old May 2, 2012 | 09:58 AM
  #665
OkieNiteTrain
Exactly! That happens all the time. Just read the posts everyday and see what the goal is with most Harley owners. Comparing max hp/trq. Good point.
Old May 2, 2012 | 10:42 AM
  #666
BlackSpecial's Avatar
BlackSpecial
Peak numbers are important to some people. But IMO, you're better off looking at the average torque under the curve for street performance.
If you build for torque the result will be a better performing street bike and the hp will take care of itself.
Old May 3, 2012 | 06:01 AM
  #667
db133's Avatar
db133
6th Gear
Default FXSTBi 2006
2006 FXSTBI. 88 Inch. Andrews TW21 Cams. Fast Lane Street Port Heads. SE Exhaust. PC & Air filter etc.
Max Power = 80.14
Max Torque= 89.73
Old May 3, 2012 | 05:13 PM
  #668
harleytuner
Max Power = 80.14
Max Torque= 89.73
Looks a little like your clutch could be slipping.
Old May 4, 2012 | 04:32 AM
  #669
db133's Avatar
db133
6th Gear
Default Ref: Clutch Slip.
Ref: Clutch Slip. 6oz over fill in primary when I changed it.
Old May 4, 2012 | 10:03 AM
  #670
TheTroupe's Avatar
TheTroupe
Some people have asked me to re-post this. So here it is.
My goal was a broad and smooth power curve. Lots of low end torque and reasonable sound.
Starting Point: 2003 88ci. FLSTCi.
The Changes: SE Air intake with K&N Filter, Power Commander III tuned by the dealer, SuperTrapp 2:1 with 23 discs. SE 204 cam, with upgraded cam plate and SE oil pump.
Not Changed: No head work, stock push rods, stock lifters, stock valves, stock bore & stroke.
The Results:
Max torque 88 @ 2700
Max HP 81 @ 5450
