"DYNO" Numbers For SOFTAILS
Old May 29, 2012 | 09:34 PM
  #681
2deuceguy's Avatar
2deuceguy
07 deuce 96" tw-555 cams, fuelmoto pushrods, woods lifters, kuryakyn hi-v mach 2 a/c, kuryakyn crusher power cell pipes. 87 horse 95 ft/lbs torque
03 deuce 95" tw6-6r cams, woods cam plate and oil pump, fuel moto pushrods, woods lifters, d&d spike air cleaner, sampson big guns pipes(no baffles) 82 horse 97 ft/lbs torque
i'll post the sheets as soon as i can figure out how
Old May 29, 2012 | 10:50 PM
  #682
2deuceguy's Avatar
2deuceguy
this is for the 03
this is for the 07
Old Jun 2, 2012 | 08:36 AM
  #683
Road_Clam's Avatar
Road_Clam
2006 FLSTFI
Revolution Cycle 97" kit
Revolution Cycle street ported heads
9.8:1 CR
PC III , w/ "off the shelf" 95" map
Andrews 54G gear cam conversion
V&H Straight Shot HS 2" pipes, Thunder City Monster baffles
SE injectors
SE filter kit
93.2 hp / 99 ft/lb torque per Rob's Dyno Service (and I really need a better advanced tune, as my a/f ratios were all over the place both too rich and too lean )
Power really smacks you in the face at about 3900 rpm's and pulls very broad torque all the way to 5500 rpm's. Don't bother winding my engine past 6K cause it's all done and power drops off considerably. Sorry I did get a dyno printout, but I don't have a scanner and the print is kinda' $hitty and small. Getting about 39 mpg as well, very respectable IMO considering the mod list.
Old Jun 2, 2012 | 10:45 AM
  #684
Yabiah's Avatar
Yabiah
Default 2010 Heritage
Some educated opinions desired regarding my HP/Torque & Air/Fuel ratio would be appreciated.
I get a consistent 36mpg riding back & forth to work (30 mile round trip) which is 90% freeway at 70+mph.
HP 72.03
Torque 85.75
Attached Thumbnails "DYNO" Numbers For SOFTAILS-dyno1.jpg   "DYNO" Numbers For SOFTAILS-dyno2.jpg
Old Jun 2, 2012 | 10:49 AM
  #685
sgod1100's Avatar
sgod1100
yeah, she hauls ***! Can't remember if i posted this or not, so here it is again
Old Jun 3, 2012 | 03:12 PM
  #686
refg3880's Avatar
refg3880
my 02 fxst 95 incher, stock casting heads and cylinders wood 9fg cams roller rockers cv 51 zippers ac hillside stage 4 heads white bros 2 into 1 pipe
my 2007 fxstbi 107 incher stock casting heads cylinders s&s 585 cams STOCK T-BODY hillside stage 4 heads d&d fat cat tts mastertune dynoed and tuned by joe's
Old Jun 3, 2012 | 06:42 PM
  #687
TheTroupe's Avatar
TheTroupe
For those if use who are unfamiliar with this setup can you explain:
and
Thanks
Old Jun 3, 2012 | 08:04 PM
  #688
refg3880's Avatar
refg3880
Wink
and
Thanks
my org stock heads and cylinders reworked. no s&s or axtell no cnc ported tags s&s tags, stock head casting reworked to spec, bikes are "bone stock" no screamin eagle name plates ect hillside cycle stage 4 porting
Old Jun 6, 2012 | 08:15 PM
  #689
TheTroupe's Avatar
TheTroupe
I'm just lost here... bone stock - reworked - no S&S but you have S&S... WTF
Old Jun 6, 2012 | 08:51 PM
  #690
harleytuner's Avatar
harleytuner
Stock cylinders that have been bored out to fit the aftermarket pistons. He's saying that he didn't just buy a 95" kit out of a catolog that came with pistons and jugs.
