"DYNO" Numbers For SOFTAILS
Old Jul 30, 2009 | 07:30 PM
  #181
jd8181's Avatar
jd8181
sedeluxe is that all your bike has got?!?!? gosh i think my huffy 10 speed could out run that those are some sweet numbers.
did you have baisley's custom build your heads? i plan on have baisley's do my head once i come with the money. also what was there turn around time on the heads?
tell us what all the motor as in it? and what did you do with the clutch? and did you go chain?
Old Jul 30, 2009 | 07:52 PM
  #182
SEDELUXE's Avatar
SEDELUXE
Those are the pro street heads. i waited a while for those heads when my build got started it was in the winter so that is Dan Baisley busy time. altho he has been busy all yr for the last few yrs.
Those are Dans middle of the road head. the top of the line heads are the hy-breds i would love to get a set of those butthose heads are built to order and most of the racers get in line first to have him do those heads
You have to remember Baisley is a made to order shop. he has cores he works off but you tell him what ya want then he builds the heads for you.
what ever the turn around time is it is well worth it.
Old Jul 31, 2009 | 06:37 AM
  #183
imrotton2's Avatar
imrotton2
awsome numbers,,, kinda makes us all want more,,, ride safe
Old Aug 1, 2009 | 03:55 PM
  #184
BlackSpecial's Avatar
BlackSpecial
Default Khrome Werks vs. Rush 2.0 dyno
Here are the numbers from the baseline dyno I had done today. No tuning or other mods.
Khrome Werks HP+ slip-ons (blue line) vs. Rush 2.0 slip-ons (red line).
The 2nd sheet is the roll-on showing average air fuel ratio in closed loop.
Attached Thumbnails "DYNO" Numbers For SOFTAILS-khromewerksdyno.jpg   "DYNO" Numbers For SOFTAILS-khromewerksafr.jpg
Old Aug 14, 2009 | 08:43 PM
  #185
Roosterboots's Avatar
Roosterboots
"Utopian Overlord"
2002 Heritage, K&N filter, SE-II slip ons, 48 slow jet, CV Performance needle/emulsifier/slide spring, EZ Just mixture needle. Roadhog Motorcycles dyno tuning trailer at Sturgis, MS. Red lines indicate #190 main jet, Blue lines are #185 main jet (final setting).
Old Aug 16, 2009 | 07:58 AM
  #186
NTrain177's Avatar
NTrain177
2008 Night Train 80 HP and 92TQ. Andrews 26H cam V&H Fuelpak V&H 2-1 Pro Pipe and wimmer filter on SE back plate.
Old Aug 17, 2009 | 09:25 PM
  #187
NTrain177's Avatar
NTrain177
here is my dyno chart
Old Aug 18, 2009 | 09:41 PM
  #188
kkinderen's Avatar
kkinderen
Just finished the initial run today. I was hoping for better numbers but I'm going to try again in the fall when I have more miles on the motor.
Here's the latest mods to the 2003 Carb'd Fat Boy
S&S Hot Setup Kit 106"
Feuling Oil Pump
Mikuni HSR45 Carb
TC88 Daytona Twin TEC Ignition Module
Timken Bearing Assempbly
Baker 6-speed Transmission
S&S Cylinders/Pistons 10.5:1
Arlen Ness Big Sucker
Vance & Hines Big Radius 2-into-1
TQ 103.4@3700
HP 88.4@5500
Old Aug 19, 2009 | 03:48 AM
  #189
armychopper06's Avatar
armychopper06
95" kit
Installed:
-JE forged pistons 10 1/4:1 -Screaming eagle 258 cams
duration @ .053 258/268 degrees lift .569"/.569" -Screaming eagle twin cam performance heads/ smoothed&pocket ported -TP roller rockers
-Bassani chopper pipes, no baffles
103 hp
100 lbs ft.
Old Aug 19, 2009 | 10:59 AM
  #190
beaureed445's Avatar
beaureed445
I don't have the dyno sheet loaded, but my latest 103" is making
107/107.....Getting torn down for a 113" in October.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
