"DYNO" Numbers For SOFTAILS
Old Sep 8, 2009 | 07:43 AM
  #201
imrotton2's Avatar
imrotton2
how your bike runs in tn. and how it will run in fl. are two different stories... what runs strong in one place mite flop in the other... i suggest getting it dynoed at a local to your area shop....JMO
Old Sep 10, 2009 | 08:16 AM
  #202
nikonf8's Avatar
nikonf8
Default dyno
I never had mine on the dyno and as far as I am concerned I do not need to waste the money. My bike runs great. no hesitation it just gets up and goes when i twist it. i look at my plugs and it they tell me that i am running well. so i feel there is no need to waste the money on a dyno tune. as far as numbers go most bikes running what i have stage four every thing but a stroker kit are getting the magic 100 100 give or take a point or two with that being said no need to spend 500 or so on a tuner and dyno tune. i guess maybe i got lucky i went all Harley and the download they used has done the job. when i went to the Vance and hines true duels i went with the quiet baffles and lucked out again no problems a while back i decided to slip the baffles in that came with the pipes they are louder my bike ran like crap low end hesitation not enough back pressure i then put the quiet baffles back in with out the packing around them and bingo running like a top and louder. stock baffles that come with the Vance and hines true duels are opened on the end the quiet baffles have a cap on the end that creates more back pressure.
Old Sep 10, 2009 | 02:33 PM
  #203
BlackSpecial's Avatar
BlackSpecial
One man's "waste" of money is another man's optimized tune.
The dyno is a tool. If you choose not to take advantage of it's capabilities, so be it.
I haven't made enough changes to my bike to justify a full session for tuning. But having verified the a/f ratio (before & after installing slip-ons) with a baseline dyno run ($55) has given me peace of mind that was well worth the money.
Old Sep 10, 2009 | 03:28 PM
  #204
Ricks2006's Avatar
Ricks2006
imrotton2 The bike was dyno in fl. I had it dyno in TN. and it made more power better air.
Old Sep 14, 2009 | 05:22 PM
  #205
mike06train's Avatar
mike06train
Nikonf8, glad to hear your bike is running good. But, I paid $100.00 for my dyno tune when I got my cams done. It would of cost me $200 if I just got the tune alone. I don't know who was going to charge you $500 but I wouldn't pay that either.
Old Sep 18, 2009 | 02:11 PM
  #206
Jonoto's Avatar
Jonoto
6th Gear
Default Dyno
'07 fxstc, 103 stage II, V&H BR 2-2, std. dyno
HP-76.41
Tq-96.6
Old Sep 18, 2009 | 02:15 PM
  #207
Jonoto's Avatar
Jonoto
6th Gear
Hey GregH:
Got a custom myself and really dig your apes. How big and what kind are they? thinking of doing something similar myself.
Old Sep 19, 2009 | 10:55 PM
  #208
oct1949's Avatar
oct1949
Originally Posted by NTrain177
2008 Night Train 80 HP and 92TQ. Andrews 26H cam V&H Fuelpak V&H 2-1 Pro Pipe and wimmer filter on SE back plate.
Nt that is almost the same lines I got 92TQ and 80HP with over 80TQ at 2K... I really like the 26h cam in our Heritage, great low TQ line and thats where we wanted it for our riding.
My sheet is the 1st one in this thread, I started it...thanks
Originally Posted by beaureed445
I don't have the dyno sheet loaded, but my latest 103" is making
107/107.....Getting torn down for a 113" in October.
I've seen this several times now, when I put the cams in and got 92/80 and can really feel the difference and Urs has 107/107 and Ur wanting more, I just can't imagine what 20% more would do,. I bout throw Grandma off the a$$ end now with just what we have.....probably looose our teeth..
Old Sep 21, 2009 | 12:58 PM
  #209
Stoood's Avatar
Stoood
Default More Hp for your fine looking scooter?
This one was in reply to Richs2006 quest for 100+ Hp, not sure how it ended up here!
With the head work you've done I think you'd be happier with a bigger cam (and a 2 into 1 exhaust, like a D&D Fatcat). Our motors are "similar", and I'm very happy running an Andrews TW55. John Sacks designed the grind, and it pulls like a frieght train from 2000 to 6200, where I have the rev. limiter set. And check out the flat torque curve. With the right Dyno tune you should fly past 100hp, IMHO. -It's like a disease, I just got the one put together and I'm planning another, know what I mean? Keep the tack in black!
Last edited by Stoood; Sep 21, 2009 at 01:09 PM. Reason: I responded to the wrong member!
Old Sep 22, 2009 | 05:19 PM
  #210
Schaub85's Avatar
Schaub85
Hey guys was wonderin if you could give me some insight. When I had my train tuned about a month ago she put down 76hp and 90ft/lbs. Shes runnin just a smidge on the rich side right now. But she runs sooo much better than before.
If I switch to the SE 10mm plugs is that gonna change anything? Just not sure what to expect.
Also what could I expect from a set of rockers?
