"DYNO" Numbers For SOFTAILS
Old May 21, 2010 | 02:50 PM
  #301
hdspringer02's Avatar
hdspringer02
Just had my bike on the dyno today. I don't have access to a scanner right now, so I can't post the sheet.
2002 FXSTS 88ci
Roland Sands air cleaner
V&H short shots w\BCT baffles
SE 204 cams
torque: 92.36
HP: 75.21
The guy who did it said that if I swapped pipes I should be able to come pretty close to 80 HP and 100 TQ. I am not a fan of the way that the 2-1 looks, but he said that if I went to 2-2 with a larger diameter I would see a decent gain. Anyone have any suggestions?
Old May 23, 2010 | 10:47 AM
  #302
Stoood's Avatar
Stoood
Thumbs up 103, Red Shifts, Stk Heads, is 100 HP Next?
I've been tracking builds using the newerTC Heads (stock). With the Red Shift cams, stepped exhaust, and Fuelmoto map, I'm guessing if you don't make 100, you should be darned close! What's your compression ratio with the dished Wisecos, 9.5 to one? My flat-tops gave me 9.8 in one of my motors, I milled the heads and decked the Jugs on the other to get above 10 to 1 with NO pre-ignition problems on 91 pump gas (.550 lift cams, in 22/46, ex 52/20, Duration 248/252). I used a Fat Cat 2 : 1, Love it, Like my V&H duals with Python mufflers on theTrike too, man do they Bark!
Happy Wrenching!
-Stoood
103" using wiseco dished pistons
red shift 575's
K&N filter
khromeworks AR100 2-2 exhaust
PCV retrofit from fuelmoto
stock heads
84.75hp
92.68tq
Old May 28, 2010 | 09:43 AM
  #303
montrealbob's Avatar
montrealbob
Here's my Dyno sheet for my 2007 Softail custom with the following mods: RSD air intake, 2 into 1 Supertrapp with 24 discs, Race tuner, Woods 6 cams.
Old Jun 1, 2010 | 10:24 AM
  #304
buffdds's Avatar
buffdds
Default 1999 Fatboy Dyno
I had mine dyno'd @ Tilley's in Statesville, NC
My 80 in EVO has 81.74HP, and 89.66ft-lbs of torque.
Screamin Eagle High Perf Heads
Screamin Eagle High Comp 10.5:1 Forged Pistons +.010 o/s
Andrews EV 27 Cam
Mikuni 42mm Flatside Carburetor
Crane HI4 Fireball Race Perf Ignition Module
Big City Thunder Monster Baffles on drag pipes
Screamin Eagle Perf Coil,Plugs,Wires
Old Jun 4, 2010 | 09:22 AM
  #305
igotmineinoif's Avatar
igotmineinoif
Talking 08 Train
V&H Big shots
Stage I intake with K&N filter
Fuel Pack
Dyno said 78 HP / 90 FT LB
pulls like a champ, plan for a 103" upgrade, cams (not selected yet), and maybe see about some flow work on the heads. Id like to get above 110!
Old Jun 6, 2010 | 02:51 PM
  #306
Stoood's Avatar
Stoood
Thumbs up The Magic 100/100
If you want 100+ Hp, just use the same components I did on the Springer in my signature. I think the TTS tuner is better, & the Kury 37mm intake w/ the hi-flow injectors made a huge difference. I like the Andrews TW55 cams really well, it pulls way past 6000 and is still street friendly. I had the porting done by Jon Sachs, valves are 1.9 and 1.625. On the net it's "Sachs Race Bike" (he actually designed the TW55 grind for Andrews, so the heads work well with the cams). I haven't had my trike on the Dyno yet, but the SE204 cams with the 1.725 to 1 rockers really pull hard to 5000 rpm (wheelies possible), and that was a fairly simple build (stock heads w/ springs). Use SE's beehive springs to be on the safe side if you start adding lift above 0.500. A Fatcat 2 into 1 is a must IMHO. Much better than the duals on my trike. Good Luck!
Old Jun 7, 2010 | 04:26 PM
  #307
barmstrong's Avatar
barmstrong
Stage I
Just signed up for this so I hope all my mods print up.
My 103 puts out 98.5 hp and 107 ft
Old Jun 8, 2010 | 08:18 AM
  #308
mike06train's Avatar
mike06train
Default My dyno sheet
I don't know if this worked or not but here is the dyno results.
HP is 91.21 and tq is 84.12
I have a 95" kit with 10.25:1 pistons to install. I think the torque numbers will improve alot when I get around to doing the work.
Old Jun 15, 2010 | 11:12 AM
  #309
hspring03's Avatar
hspring03
Welcome to the 100horsepower club.....
2003 FLSTSI
SE High Compression Package
257 Cam
Bassani Road Rage Long 2 in 1
Old Jun 17, 2010 | 02:21 PM
  #310
NightTrainRob's Avatar
NightTrainRob
My motor is broke in and taking a trip tomorrow with the bike on vacation and leaving it at Cycle-Rama to get tuned. Here is what I have so far, I'll post up the numbers when its tuned
2005 NightTrain
95"
SE high comp. forged pistons
Cycle Rama heads
CR 575 cams
Gear Drive
45 Mikuni with ported intake
Daytona Twin Tec. ign.
D&D Fatcat
Called me today and told me the bike was ready, he told me it was 102 hp and 107tq. I'll post the dyno sheet in the next few days after I pick the bike up and make the trip back up to N GA
